Topic: Need some pointers on some code (Read 5599 times) previous topic - next topic
oniudra_-
Feb 01, 2013, 10:05 pm Last Edit: Feb 01, 2013, 10:48 pm by oniudra_- Reason: 1
Good day to all.
Im a real newbie to all of this coding but Im learning each day   :smiley-roll-sweat:
I guess this code would seem pretty basic to you guys so here's what Im busy with.
I found this code on the net and Im controlling the 7 segment to count up and down when you turn the potentiometer knob.
Iv changed it a bit to get what I want on the display, cut down the counts to only 7 diffrent numbers aswell.
All works fine but want to add in a switch to turn off the write 3 and turn on write 4 and coil a relay.
Iv still got 5 digital pins open.
Arduino uno
7 segment display ( 1 digit)
Potentiometer
Relays and transistor
Here is the code
Thanks
//Potentiometer controlling 7-segment LED
//declare variables
const int pot = A0; // Potentiometer to Analog pin A0
  // To 7 segment display
  pinMode(2, OUTPUT); //3-A
  pinMode(3, OUTPUT); //9-B
  pinMode(4, OUTPUT); //6-C
  pinMode(5, OUTPUT); //5-D
  pinMode(6, OUTPUT); //4-E
  pinMode(7, OUTPUT); //2-G
  pinMode(8, OUTPUT); //1-F
delay(10);
int sensorReading = analogRead(pot);
delay(10);
// Segment shows P on start
  if(sensorReading == 0){
   //write 0
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 0);
   delay(10);
  // Segment shows R when potentiometer is turned
  if(sensorReading > 0 && sensorReading <= 113){
   //write 1
   digitalWrite(2, 0);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // Segment shows N
  if(sensorReading > 113 && sensorReading <= 226){
   //write 2
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // Segment shows D
  if(sensorReading > 226 && sensorReading <= 339){
   //write 3
   digitalWrite(2, 1);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
  // Need it to turn off the write 3 when a switch is pushed at this point and show write 4
  // Iv removed write 4 here so at this point it skips this number.
  // Also looking for it to strik a relay at the same time
   // Segment shows 2
   if(sensorReading > 452 && sensorReading <= 565){
   //write 5
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
  // Segment shows L
  if(sensorReading > 565 && sensorReading <= 678){
   //write 6
   digitalWrite(2, 1);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
Arrch
HazardsMind
#2
Feb 01, 2013, 10:15 pm Last Edit: Feb 01, 2013, 10:25 pm by HazardsMind Reason: 1
//point
//point
//point
//point
//point
Sorry, couldn't resist.  LOL XD
Ok joking aside, look into direct port manipulation, so you can use binary (0b00000000 , 0b00100101 ... 0b11111111) to change your output states.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
nickgammon
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
oniudra_-
Thanks...like I said Im a real newbie. :smiley-zipper:
Iv got the numbers 1 to 7 showing as I turn the knob in one direction and when I turn it back it counts back down.
At the 3rd display when turning the knob I need to then flip a switch and it shows up the 4 th digit without turning the knob.
hang on,,, I am the knob here  :D
oniudra_-
Ok I will...sorry I found it like this on the net
Arrch
You still need to define your requirements a little more. Do you mean the switch will act as an override?
oniudra_-
Thats it yes Im looking to have a condition in there of some sort so that it removes that 3 rd display with out moving the potentiometer.
Im busy making a gear shifter display and the gear shifter don't move only in a up and down motion.... got a right movement which
Im trying to use a switch for that
Arrch
What do you mean "3rd" display? I thought you only had one digit?
oniudra_-
Will state that better......Got a one digit 7 segment and mean it like this
No 0= Park ( P)
No 1= Reverse ( R )
No 2= Nutral (N )
No 3 = Drive ( D )
No 4 = Three  (3)              need the three to work from a switch and blank out drive without moving the potentiometer.
No 5 = Two    (2)
No 6 = Low     (1)
Arrch
Still not sure I understand, but here is a general answer:
if switch is pressed
  do your override stuff
  check potentiometer
  do potentiometer stuff
If you need help reading the state of a switch, just take a look ant many of the examples posted.
PeterH
Something like:
if((digitalRead(switchPin) == LOW) && (gear == 3))
    gear = 4;
I'm assuming your switch input is active low.
oniudra_-
I see thanks....yes will be low state
will give it a bash
Thanks
oniudra_-
Thanks guys I got my switch to work  :)
Sorry for all these basic questions but I suffer with dyslexia so takes me a bit of time.
always willing to ask and learn tho.
Iv added in a fade on the 7 segment with the help of  opensource hardware junkies.com...he's site is great. step by step..
Im trying to fade the whole array but it seem to have a problem adding in the 2 to 8 digital pins for some reason.
Also seems to complain about sensorReading now which it had no problem with before I added this new function in.
Thanks
//declare variables
const int SW = 9; // Switch in
const int analogInPin = A1;
const int analogOutPins = 2,3,4,5,6,7,8;
int fadeValue = 0;
int outputValue = 0;
  pinMode(9, INPUT_PULLUP); // Switch in
delay(10);
delay(10);
int digitalValue = digitalRead(SW);
delay (100);
fadeValue = analogRead(analogInPin);
//Map to range of analog out
outputValue = map(fadeValue, 0,1023, 0, 255);
// change the analog out value
analogWrite(analogOutPins, outputValue);
Serial.print("sensor = ");
Serial.print(fadeValue);
Serial.print("\t output = ");
Serial.println(outputValue);
delay(2);
// P
   //write 0
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 0);
   delay(10);
  // R
   //write 1
   digitalWrite(2, 0);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // N
  if(sensorReading > 150 && sensorReading <= 226){
   //write 2
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // D
  if(sensorReading > 226 && sensorReading <= 290){
   //write 3
   digitalWrite(2, 1);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
   // Segment shows 3
  if(digitalRead(SW)==LOW){
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 0);
   digitalWrite(6, 1);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(200);
   // Segment shows 2
   if(sensorReading > 350 && sensorReading <= 565){
   //write 5
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
  // Segment shows L
   //write 6
   digitalWrite(2, 1);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
Chaul
Please work on indentation. I'm having trouble reading what the loop() does. It seems like either a function definition was missing after the loop and before the first, or there is one extra bracket in the middle.
Also, if you are reading a potentiometer, you can't really trust that it's steadily at 0 for a long period of time. It could keep switching between states P and R. Does it do anything if sensorReading was > 678? It would seem to keep the previous state, whatever it was.
You can shorten the code by wrapping the digitalWrites into a function with the 7 pins' states and the delay as parameters. That's 2 or 8 parameters, your choice.
