Pages: [1] 2   Go Down
Author Topic: Need some pointers on some code  (Read 286 times)
Good day to all.
Im a real newbie to all of this coding but Im learning each day   smiley-roll-sweat
I guess this code would seem pretty basic to you guys so here's what Im busy with.
I found this code on the net and Im controlling the 7 segment to count up and down when you turn the potentiometer knob.
Iv changed it a bit to get what I want on the display, cut down the counts to only 7 diffrent numbers aswell.
All works fine but want to add in a switch to turn off the write 3 and turn on write 4 and coil a relay.
Iv still got 5 digital pins open.
Arduino uno
7 segment display ( 1 digit)
Potentiometer
Relays and transistor
Here is the code
Thanks
//Potentiometer controlling 7-segment LED
//declare variables
const int pot = A0; // Potentiometer to Analog pin A0
  // To 7 segment display
  pinMode(2, OUTPUT); //3-A
  pinMode(3, OUTPUT); //9-B
  pinMode(4, OUTPUT); //6-C
  pinMode(5, OUTPUT); //5-D
  pinMode(6, OUTPUT); //4-E
  pinMode(7, OUTPUT); //2-G
  pinMode(8, OUTPUT); //1-F
 delay(10);
 int sensorReading = analogRead(pot);
 delay(10);
// Segment shows P on start
  if(sensorReading == 0){
   //write 0
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 0);
   delay(10);
  // Segment shows R when potentiometer is turned
  if(sensorReading > 0 && sensorReading <= 113){
   //write 1
   digitalWrite(2, 0);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // Segment shows N
  if(sensorReading > 113 && sensorReading <= 226){
   //write 2
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // Segment shows D
  if(sensorReading > 226 && sensorReading <= 339){
   //write 3
   digitalWrite(2, 1);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
  // Need it to turn off the write 3 when a switch is pushed at this point and show write 4
  // Iv removed write 4 here so at this point it skips this number.
  // Also looking for it to strik a relay at the same time
   // Segment shows 2
   if(sensorReading > 452 && sensorReading <= 565){
   //write 5
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
  // Segment shows L
  if(sensorReading > 565 && sensorReading <= 678){
   //write 6
   digitalWrite(2, 1);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
« Last Edit: February 01, 2013, 04:48:53 pm by oniudra_- » Logged
California
Online Online
What does that mean?
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
//point
//point
//point
//point
//point
Sorry, couldn't resist.  LOL smiley-lol
Ok joking aside, look into direct port manipulation, so you can use binary (0b00000000 , 0b00100101 ... 0b11111111) to change your output states.
« Last Edit: February 01, 2013, 04:25:12 pm by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Melbourne, Australia
Shannon Member
Lua rocks!
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Thanks...like I said Im a real newbie. smiley-zipper
Iv got the numbers 1 to 7 showing as I turn the knob in one direction and when I turn it back it counts back down.
At the 3rd display when turning the knob I need to then flip a switch and it shows up the 4 th digit without turning the knob.
hang on,,, I am the knob here  smiley-grin
Ok I will...sorry I found it like this on the net
California
Online Online
You still need to define your requirements a little more. Do you mean the switch will act as an override?
Thats it yes Im looking to have a condition in there of some sort so that it removes that 3 rd display with out moving the potentiometer.
Im busy making a gear shifter display and the gear shifter don't move only in a up and down motion.... got a right movement which
Im trying to use a switch for that
California
Online Online
What do you mean "3rd" display? I thought you only had one digit?
Will state that better......Got a one digit 7 segment and mean it like this
No 0= Park ( P)
No 1= Reverse ( R )
No 2= Nutral (N )
No 3 = Drive ( D )
No 4 = Three  (3)              need the three to work from a switch and blank out drive without moving the potentiometer.
No 5 = Two    (2)
No 6 = Low     (1)
California
Online Online
Still not sure I understand, but here is a general answer:
if switch is pressed
  do your override stuff
  check potentiometer
  do potentiometer stuff
If you need help reading the state of a switch, just take a look ant many of the examples posted.
UK
Something like:
if((digitalRead(switchPin) == LOW) && (gear == 3))
    gear = 4;
I'm assuming your switch input is active low.
I see thanks....yes will be low state
will give it a bash
Thanks
Thanks guys I got my switch to work  smiley
Sorry for all these basic questions but I suffer with dyslexia so takes me a bit of time.
always willing to ask and learn tho.
Iv added in a fade on the 7 segment with the help of  opensource hardware junkies.com...he's site is great. step by step..
Im trying to fade the whole array but it seem to have a problem adding in the 2 to 8 digital pins for some reason.
Also seems to complain about sensorReading now which it had no problem with before I added this new function in.
Thanks
//declare variables
const int SW = 9; // Switch in
const int analogInPin = A1;
const int analogOutPins = 2,3,4,5,6,7,8;
int fadeValue = 0;
int outputValue = 0;
  pinMode(9, INPUT_PULLUP); // Switch in
 delay(10);
 delay(10);
int digitalValue = digitalRead(SW);
 delay (100);
fadeValue = analogRead(analogInPin);
//Map to range of analog out
outputValue = map(fadeValue, 0,1023, 0, 255);
// change the analog out value
analogWrite(analogOutPins, outputValue);
Serial.print("sensor = ");
Serial.print(fadeValue);
Serial.print("\t output = ");
Serial.println(outputValue);
delay(2);
// P
   //write 0
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 0);
   delay(10);
  // R
   //write 1
   digitalWrite(2, 0);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // N
  if(sensorReading > 150 && sensorReading <= 226){
   //write 2
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 1);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
  // D
  if(sensorReading > 226 && sensorReading <= 290){
   //write 3
   digitalWrite(2, 1);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
   // Segment shows 3
  if(digitalRead(SW)==LOW){
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 0);
   digitalWrite(5, 0);
   digitalWrite(6, 1);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(200);
   // Segment shows 2
   if(sensorReading > 350 && sensorReading <= 565){
   //write 5
   digitalWrite(2, 0);
   digitalWrite(3, 0);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 1);
   digitalWrite(8, 0);
   delay(10);
  // Segment shows L
   //write 6
   digitalWrite(2, 1);
   digitalWrite(3, 1);
   digitalWrite(4, 1);
   digitalWrite(5, 0);
   digitalWrite(6, 0);
   digitalWrite(7, 0);
   digitalWrite(8, 1);
   delay(10);
Finland
Please work on indentation. I'm having trouble reading what the loop() does. It seems like either a function definition was missing after the loop and before the first, or there is one extra bracket in the middle.
Also, if you are reading a potentiometer, you can't really trust that it's steadily at 0 for a long period of time. It could keep switching between states P and R. Does it do anything if sensorReading was > 678? It would seem to keep the previous state, whatever it was.
You can shorten the code by wrapping the digitalWrites into a function with the 7 pins' states and the delay as parameters. That's 2 or 8 parameters, your choice.
Pages: [1] 2   Go Up
