Hi all,
I'm fairly new to Arduino and I'm just a hobby-coder, not a professional by a long shot. I'm working on my first bigger project and I have written a bunch of convenience functions to control eDIPTFT-series intelligent displays from Electronic Assembly. With the help of the forum, I now converted this collections of functions in a .ino file into a libray.
Now, my problem. Those displays use serial communication and I want to hand over the serial port to use for communications in a parameter in the constructor:
EDIPTFT::EDIPTFT(int port, int smallprotocol) {
_port = port;
_smallprotocol = smallprotocol;
Then, the sendData() function checks this parameter and decides which
port to use:
void EDIPTFT::sendData(char* data, int len) {
if (_smallprotocol > 0) {
else {
unsigned char i;
for(i=0; i < len; i++) {
switch (_port) {
case 0 : {
Serial.write(data[i]);
break;
case 1 : {
Serial1.write(data[i]);
break;
case 2 : {
Serial2.write(data[i]);
break;
case 3 : {
Serial3.write(data[i]);
break;
Trouble is, I can't get it compiled. The sketch I'm writing in my main project includes the FastSerial library which is needed by some other libraries I also use. Now, when I try to compile my sketch with my EDIPTFT library, I get these errors:
core.a(HardwareSerial.cpp.o): In function `global constructors keyed to rx_buffer':
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_25'
UxV_CS.cpp.o:/opt/arduino-1.0.3/UxV_CS.ino:79: first defined here
/opt/arduino-1.0.3/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_36'
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_51'
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_54'
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `Serial'
/opt/arduino-1.0.3/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: Warning: size of symbol `Serial' changed from 29 in UxV_CS.cpp.o to 34 in core.a(HardwareSerial.cpp.o)
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `Serial1'
/opt/arduino-1.0.3/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: Warning: size of symbol `Serial1' changed from 29 in UxV_CS.cpp.o to 34 in core.a(HardwareSerial.cpp.o)
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `Serial2'
/opt/arduino-1.0.3/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: Warning: size of symbol `Serial2' changed from 29 in UxV_CS.cpp.o to 34 in core.a(HardwareSerial.cpp.o)
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `Serial3'
/opt/arduino-1.0.3/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: Warning: size of symbol `Serial3' changed from 29 in UxV_CS.cpp.o to 34 in core.a(HardwareSerial.cpp.o)
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_26'
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_37'
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_52'
/opt/arduino-1.0.3/hardware/arduino/cores/arduino/HardwareSerial.cpp:515: multiple definition of `__vector_55'
Could somebody help me out with that, please?
The complete code of my library is at
https://github.com/sgofferj/EDIPTFT-Stefan
