Loading...
Pages: [1]   Go Down
Author Topic: X-Ray detector/sensor  (Read 588 times)
Offline Offline
Newbie
View Profile
I want to install an x-ray detector linked to a GPS/GMS unit into a vehicle (e.g. commercial trailer), so I can monitor when and where the vehicle gets x-rayed.  The x-ray detector only needs to detect the presence of x-rays (no need for imaging, etc...).  Are there any good x-ray sensing components on the market that can be employed with Arduino (or without) to accomplish this job?
Thanks for the input!
Logged
Offline Offline
Edison Member
View Profile
X-rays is gamma radiation ?
So a Geiger counter could detect it.
Or you could use a PIN diode:
http://en.wikipedia.org/wiki/PIN_diode
http://arduino.cc/forum/index.php?topic=119380.0
But I understood it is not easy to get a reliable measurements with a PIN diode.
Or search for: X-ray sensor.
« Last Edit: February 01, 2013, 06:52:24 pm by Krodal » Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
There is an article: http://www.elektor.com/magazines/2011/november/improved-radiation-meter.1971931.lynkx?tab=2
you may try to replicate with arduino, sensor is pin diode BPW34
Logged
Offline Offline
Edison Member
View Profile
The BPW34 (or BPW34F) seems to be the only useable PIN Photo Diode for a normal price.
It is not very sensitive, it can't be used to detect the background radiation.
It is a photo diode, so you have to place it in the dark.
Some schematics:
http://www.vk2zay.net/article/265
http://www.dgkelectronics.com/a-radiation-detector-with-a-solid-state-pin-diode-sensor/
http://www.mikrocontroller.net/topic/216426
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
What good comes out of X-raying a car, I would think the metal skin would either absorb or scatter all of the radiation leaving little to image with?
Logged
Offline Offline
Full Member
View Profile
It's a trailer.
May be scanned for illegal immigrants, drugs, munitions, or maybe to check it's speed smiley-wink
Logged
For whom does the clock pulse? It pulses for you!
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
No.
You'll need a scintillator, or something that fluoresces in X-ray.
Like diamond.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Are you trying to smuggle illegal immigrants?
I am intrigued as to why you want to do this.
Logged
Offline Offline
Full Member
View Profile
Looks like he's mapping x-ray (speedgun?) locations.
If it were customs checks, they are likely to be fixed at known locations (ports) or at random, one-off locations.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
X-band != x-ray
Logged
0
Offline Offline
Newbie
View Profile
Geiger - Muller tube will detect x-rays.  Many designs for the low-current high voltage power supply can be found online.  Old Soviet G-M tubes can  be gotten at reasonable prices.
PIN photodiodes do not require high voltages but the extremely low current signal output makes them subject to noise pickup unless well shielded.
Scintillation crystal + photomultiplier detectors are the most linear, quite sensitive, and can be very efficient, but are more costly and also require high voltage.
Overall I would recommend the G-M tube approach.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
What is a Grumpy Mike tube then?
Logged
Offline Offline
Full Member
View Profile
Laughed so much I choked! smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
