Author Topic: Shift register  (Read 592 times)
Hi guys,
          I have a number that needs to be shifted out
        I have 3 pins remaining(pins 1,2 & 13) in arduino uno.
         can i use this TX and RX pins to drive a shift register like 74HC595 ?
         how can i convert my decimal no to binary and shift it out through a pin like say pin 1 ?
Boston area, metrowest
Online Online
Author of "Arduino for Teens". Available for Design & Build services. Now with Unlimited Eagle board sizes!
Yes, if you are not planning on any serial comm's.
Use shiftout and define the pins you want to use.
If you use
shiftout(dataPin, clockPin, MSBFIRST, data_to_send);
it will go out as binary.  128D = 0x80, 255D = 0xFF, etc. No conversion needed.
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17.
Arduino for Teens available at Amazon.com.
for (int j = 15; j ==0; j--)
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, LSBFIRST, j);
    digitalWrite(latchPin, HIGH);
will this code give the output as decreasing from 15 to 0 with a delay of 1 second between each digits at a seven segment display ?
Online Online
No, you need to define a font array that maps the segments to turn on for each digit.
fontArray[] = [B00111111, B00000110, ...,}; // for 0,1,2 with bits representing DP, g,f,e,d,c,b,a and 1 = segment that is in
     a
f         b
     g
e        c
     d      DP
then
shiftOut(dataPin, clockPin, LSBFIRST, fontArray[j]);
and segments connected to the shift register accordingly.
universe
I'm enjoying my Life
I think it is all you need: http://zugiduino.wordpress.com/2012/07/11/how-to-drive-4-seven-segments-using-ic-74hc595/
Online Online
Oh, that is such a kludge of software!
universe
what do you mean with kludge?
Online Online
This whole kludge here:
void show(int numberToDisplay,int fromLine)
113 {
114 if (numberToDisplay < 10)
115 {
116 g_registerArray [3] = g_digits [0];
117 g_registerArray [2] = g_digits [0];
118 g_registerArray [1] = g_digits [0];
119 g_registerArray [0] = g_digits [numberToDisplay];
120 }
121 else if (numberToDisplay < 100)
122 {
123 g_registerArray [3] = g_digits [0];
124 g_registerArray [2] = g_digits [0];
125 g_registerArray [1] = g_digits [numberToDisplay / 10];
126 g_registerArray [0] = g_digits [numberToDisplay % 10];
127 }
128 else if (numberToDisplay < 1000)
129 {
130 g_registerArray [3] = g_digits [0];
131 g_registerArray [2] = g_digits [numberToDisplay / 100];
132 g_registerArray [1] = g_digits [(numberToDisplay % 100) / 10];
133 g_registerArray [0] = g_digits [numberToDisplay % 10];
134 }
135 else
136 {
137 g_registerArray [3] = g_digits [numberToDisplay / 1000];
138 g_registerArray [2] = g_digits [(numberToDisplay % 1000) / 100];
139 g_registerArray [1] = g_digits [(numberToDisplay % 100) / 10];
140 g_registerArray [0] = g_digits [numberToDisplay % 10];
141 }
142 sendSerialData (g_registers, g_registerArray, fromLine);
143 }
Only need this:
i want to display two digit numbers like 99
can i do this with a single shift register?
UK
Shannon Member
To answer that you need to know the number of inputs needed to drive your display (probably at least seven per character, meaning at least fourteen in total) and the number of outputs provided by the shift register you're using. Obviously the number of outputs available from the shift register must be greater than or equal to the number of inputs needed by the display.
I only provide help via the forum - please do not contact me for private consultancy.
Online Online
Yes, but you will need 2 transistors to enable one digit or the other.
Switch back & forth between them, persistance of vision will make them both appear on.
That is how 4-digit display work also.  All the segments are wire in parallel, each digit having a unique common anode or common cathode pin; only one common pin is enabled at a time to turn on 1 digit (set of segments) at a time.
can you give me a rough sketch of the ckt for a 2 digit display using a single 74ls595
