Topic: Basic Ohms law problem (Read 5696 times) previous topic - next topic
kculm
Need some help guys & gals. And try to hold back the laughter.
What I have is a basic Ohms law problem.
Ok, I made a small project as a Joke for a co-worker. It is basically a Larson scanner  incased in acrylic.
The issue I am having is figuring out the supply voltage. You see as I was making it I was using my Switching Power supply set at 5v. I used  5 Volts because of the atTiny85 and I was planning on using a 5v wall wart that I have.
Everything was working great on until I went to use the 5v 550mA wall wart.  Witch in reality puts out 6.24vdc and makes my scanner blink crazy.
Now I know I could of used and 5v regulator. But it's to late. So I was wondering if I could use a resistor to lower the voltage. Is so can someone show  me how to figure it out.
Thanks
smeezekitty
What is the nominal current at 5v? 5v devices do not generally tolerate >5.5v too well.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
emdee
The resistor would have to precisely match your current draw to get the right voltage drop. Given your predicament the easiest route might be to just burn the extra power with a 5v zener diode to lower the voltage.
kculm
That sounds cool, but over my head. Can you explain.
Thanks
kculm
How do I figure that out?
JimboZA
#5
Feb 02, 2013, 05:33 am Last Edit: Feb 02, 2013, 05:44 am by JimboZA Reason: 1
Or throw a 7805 in there....
(We learn everyday... I had to Google "Larson scanner", now I know what it is....)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
krupski
A 7805 needs 2 to 3 volts differential in order to start regulating (i.e. 7 to 8 volts in minimum). It won't work for this application.
There's no reason why a 5 volt board won't work at 5.5.... but if it's really necessary to throw away that 1/2 volt, why not just use a series 1N4001 diode and drop 0.7v off the end of the wall wart?
The real reason that the OP's board is going nuts is not the extra 1/2 volt, but probably something else like maybe lousy filtering in the wall wart (AC ripple?).
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
smeezekitty
He said the wall wart is putting out over 6v not 5.5.
Resistors for LEDS!
CrossRoads
There are other low dropout regulators that will work with a 6.24V input. 7805 is not the only choice.
http://www.digikey.com/product-detail/en/MC33269DT-5.0G/MC33269DT-5.0GOS-ND/1479179
Vout = 5V with Vin  >=6.1V
krupski
Right you are. I gotta get to sleep... I'm seeing things. Where on earth did I get 5.5 from???
smeezekitty
Probably from my post. I mentioned 5.5v as the maximum that TTL circuits will behave normally.
Resistors for LEDS!
MaJiG
Before going too far, most wall warts have a significant internal thevenin resistance and put out a higher voltage with no load (read current).
Be sure the wall wart's voltage is measured with a reasonable load on it.
Just sayin'...
MarkT
The lesson here is that a wall-wart is unlikely to be suitable for powering digital electronics unless
used with a proper voltage regulator, or unless it is already "fully voltage regulated" internally - the
good news is that mains _USB_ wall warts are _required_ to be fully regulated to 5V - this is what you
should have gone for I think.
A resistor won't solve this problem since the load is not constant - most useful devices with a microcontroller
are varying loads - a voltage regulator adjusts itself to deal with a varying load, a resistor cannot.
If it were a simple fixed load a resistor could be used.
fungus
A diode would be better. Silicon diodes drop the voltage by about 0.7V when it passes through them. Two of them in series would drop it by 1.4V, etc.
Pretty much any diode will do, it doesn't have to be a Zener or anything special. If you want a part number, try a 1N4001.
Transistors are also diodes, a fully open BJT like a 2N2222 will also drop the voltage by about 0.7V.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
kculm
And a very important lesson it was. And i am glad I learned it now and not after making a real project. :)
