Topic: Calculating if I'm within 10% of the center of a pot (Read 2466 times) previous topic - next topic
SouthernAtHeart
This one's got me a bit stumped.  On power up, I want my bot to wait until the steering mechanism is within 10% of 'neutral'
Here's some variables I've got assigned to the min/max readings of the steering POT
steering.left
steering.right
steeringVal() is another function that returns the current reading of the POT
I'd like to make a boolean that will return TRUE if the steering is within 10% of center, or FALSE is it's not
This is as far as I got, but I'm not really sure about it...
boolean StraightAhead() {  //returns true if within 10% of center
  int steeringRange = abs(steering.left - steering.right); //the total range of the steering POT
  int steeringCenter = steeringRange / 2;  //the neutral steering position
  int tenPercent = steeringRange * .01;  //10% of the range, I think
  if (abs(steeringVal() - steeringCenter) < tenPercent) return true;
  else return false;
Krodal
#1
Feb 02, 2013, 11:02 am Last Edit: Feb 02, 2013, 11:03 am by Krodal Reason: 1
Are the steering.left and steering.right the raw values from the analogRead() functions ?
Or are they calculated values from 0 to 180 (the degrees for the pot) ?
I assume they are the raw analogRead() values.
Is steering.left always the lower value, or could steering.left be the lower value ?
How do you use the 10%. Do you want the range to be from -5% to +5% around the center ?
I see 3 problems:
(1) Your center is not the range divided by two, but you have to add the steering.right or steering.left (whatever is the lowest value).
(2) Ten percent is "0.1", you use ".01" which is 1%.
(3) A value of "0.1" or ".01" is a floating point value, and you use integers to calculate it. That is not possible.
I used many variable in the next example, to show what is going on.
// example, not tested
boolean StraightAhead( void) {
  int lowest, range, middle;
  int steering, limit_low, limit_high;
  lowest = min (steering.left, steering.right);
  range = abs (steering.left - steering.right);
  middle = lowest + (range / 2);
  limit_low = middle - (range / 20);       // 5% lower
  limit_high = middle + (range / 20);     // 5% higher
  steering = steeringVal();
  if (steering > limit_low && steering < limit_high)
    return (true);
    return (false);
robtillaart
percentiles can be calculated with weighted average
// in int math look out for overflow.
boolean straight(float margin)  // 0.10
  if (steering < (left*(0.5 + margin) + right*(0.5 - margin)) )   // becomes  left  * 0.6 + right * 0.4
    return false;
  return steering > (left*(0.5 - margin) + right * (0.5 + margin));  // becomes left * 0.4 + right * 0.6
optimized for +-10% in integer math
// as steering and  left and right are max 1024 (analog read) the peak value of the math is 5120 so will fit in an int perfectly
// all divisions are replaced by multiplications.
boolean straight(void)
  if ((steering*5) < (left*3 + right*2))
    return false;
  return (steering*5 > (left*2 + right*3) );
Rob Tillaart
SouthernAtHeart
I see 3 problems:
    return (true);
    return (false);
Thanks, yes, I see all 3 problems, and your were correct.
steeringVal(), steering.left, and steering.right  are all raw analog readings, though they typical range from 500-600 min/max, not 0-1024.  So I think what you've come up with looks like it will work.  I'll make a serial monitor debug loop and check it out.  Thanks.
SouthernAtHeart
Here's what I ended up with:
  int limit_low, limit_high;
  lowest = min (steering.left, steering.right); //the lowest of the 2
  range = abs (steering.left - steering.right); //the range from left to right
  middle = lowest + (range / 2);  //the center steering value
  limit_low = middle - (range / 20);       // 5% lower than center
  limit_high = middle + (range / 20);     // 5% higher than center
  int curentVal = steeringVal();
  if (curentVal > limit_low && curentVal < limit_high)
    return (true);
    return (false);
What is the difference between these two lines?  Are they the same?
Krodal
'void' indicates that no parameter is used. In this situation void means 'nothing here'.
retrolefty
They are functionally equivalent. One is explicitly stating that there are no variables passed to the function, the other implies it by omission. Not sure what the C/C++ standards say but the present gcc compiler is happy with either.
Lefty
michinyon
It's my understanding that the ( void ) was originally required in function declarations but
not in function definitions.
But now, either appears to be OK.
