Topic: compacting code (Read 969 times) previous topic - next topic
daveydav27
Feb 02, 2013, 09:29 am Last Edit: Feb 02, 2013, 09:38 am by daveydav27 Reason: 1
Not sure how to do this, I am not really good with coding at all. I can get things to work most of the time, But it almost always comes out sloppy, and really long winded. Here is my code that I have written, Not sure if it can be made in a more simple manner, Or if I am even on the right track. It does compile and runs exactly as I intended, Just that the code looks real inefficient. Any help would be appreciated. I am using a 74hc595 shift register for this.
Code is in the next post.
daveydav27
int latchPin = 8;             //595 pin 12
int clockPin = 12;          //595 pin 11
int dataPin = 11;           //595 pin 14
//595 pin 16 connected to 5VDC
//595 pin 8 connected to GND
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
 digitalWrite(latchPin, LOW);      //When the latchPin goes from low to high, the data gets moved from the shift registers to the output pins
 shiftOut(dataPin, clockPin, MSBFIRST, B10001000);     //Using the shiftOut function to send binary 11111111 to light all LEDs.  You can change from 1 to 0 to turn off.
 digitalWrite(latchPin, HIGH);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B11000100);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B11100010);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B11110001);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B01111000);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B00110100);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B00010010);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B00000001);
 delay (1000);
 shiftOut(dataPin, clockPin, MSBFIRST, B11110000);
 delay (50);
 shiftOut(dataPin, clockPin, MSBFIRST, B00001111);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 shiftOut(dataPin, clockPin, MSBFIRST, B00000000);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
 delay (50);
daveydav27
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
  delay (50);
daveydav27
#3
Feb 02, 2013, 09:36 am Last Edit: Feb 02, 2013, 09:39 am by daveydav27 Reason: 1
Here is a video of the code working.
http://www.youtube.com/TGf034b4Wwo
Chaul
Looks like you are repeating the same sequence and writing out a different byte separated by delays. You could put all those bytes into an array and increase the index to the array each time the loop is run. You can make it return back to index 0 in the end and that requires an if statement within the loop.
UKHeliBob
I can see what you mean about your code being sloppy but you can see what is going on.
Not only is it long it is repetitive, which gives a clue as to how it might be tidied up.
Basically you are doing this each time
  delay (1000);
only the byte value changes
First stage tidy up.  Write a function to do the stuff that happens over and over again.
A function like this
void shiftData(byte value)
  shiftOut(dataPin, clockPin, MSBFIRST, value);
  delay (1000);
called like this
  shiftData(B11000100);
  shiftData(B11100010);
  //etc etc
much less typing as you can see, but that is not the end.  Now you can see another pattern.  If you could hold the byte patterns in a list and say "show the list one entry after another" it would be even neater.
Well, you can.  Put the byte data in an array, read the array entry by entry and call the function.  I suggest you get the function working first and then move on to the array.
daveydav27
Thank you for the help, I will take a look at what you are purposing I do, and see if i can figure it out. Like I said, Programming is not my strong suit at all, But I can figure out, and wire most anything.
PaulS
Once you get UKHeliBob's suggestion working, then look into Chaul's suggestion. Put all the data in an array, and call the function in a for loop.
ash901226
wow your program sure have alot of repetition, i tried the copy and paste way, the pattern stick out like a sore thumb so heres how to do it
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int Pattern1[8]=
  B10001000,
  B11000100,
  B11100010,
  B11110001,
  B01111000,
  B00110100,
  B00010010,
  B00000001,
int Pattern2[2]=
  B11110000,
  B00001111,
int Pattern3[2]=
  B11110000,
  B00000000,
int Pattern4[2]=
  B00001111;
  B00000000;
  for (int a=0;a<8;a++)
    shiftData(Pattern1[a]);
  for (int b=0;b<=7;b++)
    for (int c=0;c<2;c++);
      shiftData(Pattern2[c]);
  for ( int d=0;d<=3;d++)
    for (int e=0;e<=3;e++)
      for (int f=0;f<2;f++);
        shiftData(Pattern3[f]);
    for (int g=0;g<=3;g++)
      for (int h=0;h<2;h++);
        shiftData(Pattern4[h]);
  delay (50);
UKHeliBob
Why so many for loops, particularly the nested ones  ?  Looks to me as though one array and one for loop would do, or have I missed something
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
byte Pattern[]=
  B11000100,
  B11100010,
  B11110001,
  B01111000,
  B00110100,
  B00010010,
  B00000001
};  //etc etc
  for (int i = 0;i <= 7;i++)
    shiftData(pattern[i]);
  delay (50);
ash901226
actually UKHeliBob,
if you look closely at the op's posted code, he/she has 4 distinct pattern thus the many for loop
lloyddean
#11
Feb 03, 2013, 01:48 am Last Edit: Feb 03, 2013, 06:36 am by lloyddean Reason: 1
#define ENTRIES(ARRAY)  (sizeof(ARRAY) / sizeof(ARRAY[0]))
const uint8_t   pinLATCH    =  8;   // 595 pin 12
const uint8_t   pinCLOCK    = 12;   // 595 pin 11
const uint8_t   pinDATA     = 11;   // 595 pin 14
// 595 pin 16 connected to 5VDC
// 595 pin 8 connected to GND
struct pattern_delay_t
    uint8_t     _pattern;
    uint8_t     _delay;
pattern_delay_t data[] =
      { B10001000, 100 }
    , { B11000100, 100 }
    , { B11100010, 100 }
    , { B11110001, 100 }
    , { B01111000, 100 }
    , { B00110100, 100 }
    , { B00010010, 100 }
    , { B00000001, 100 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00001111,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B11110000,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    , { B00001111,   5 }
    , { B00000000,   5 }
    for ( int i = 0; i < ENTRIES(data); i++ )
        digitalWrite(pinLATCH, LOW);
            shiftOut(pinDATA, pinCLOCK, MSBFIRST, data[i]._pattern);
        digitalWrite(pinLATCH, HIGH);
        delay((unsigned long)data[i]._delay * 10);
    pinMode(pinLATCH, OUTPUT);
    pinMode(pinCLOCK, OUTPUT);
    pinMode(pinDATA, OUTPUT);
UKHeliBob
I was going to suggest passing 2 parameters to the function.  I would still be in favour of using a function to output the data as to me it makes it more obvious what is going on (meaningful names, easy to find in code, reusable and all that) but reading around it seems that passing a struct to a function is quite complicated, which is a shame.
PaulS
It isn't, if you define both the function and the function prototype. Passing a struct is not a good idea, though. Passing a reference to, or a pointer to, a struct is fine. The reason is that C (and C++) is a call by value language. When variables are used, the contents are copied for the function to use/manipulate/alter. Copying a structure can use a lot of memory.
Passing a pointer means that only the pointer is copied, which is a small/fast copy. With pass by reference, nothing is copied.
UKHeliBob
Thanks for the background Paul.  Passing a ponter makes sense.  I have never wanted/needed to pass a struct to a function but will do some more reading.
