Loading...
Pages: [1]   Go Down
Author Topic: Serial.readBytesUntil - will not accept a BYTE buffer  (Read 323 times)
UK
Offline Offline
Newbie
View Profile
Hello,
I've been working on reading incoming serial data.
My approach is to read packets into a local buffer.
This is working so long as my local buffer is of data type CHAR.
However, if I try to declare my buffer array as a BYTE, I get a compliation error:
SerialInvest_1.ino : In function 'void loop()':
SerialInvest_1.ino : 34: error: invalid conversion from 'byte*' to 'char*'
SerialInvest_1.ino : 34: error: initializing argument 2 of 'size_t Stream::readBytesUntil(char, char*, size_t)'
Yet, accroding to the Arduino documentation, the buffer 'should' be legitimate as a BYTE:
[http://arduino.cc/en/Serial/ReadBytesUntil]
Quote
Syntax
Serial.readBytesUntil(character, buffer, length)
Parameters
character : the character to search for (char)
buffer: the buffer to store the bytes in (char[] or byte[])
length : the number of bytes to read (int)
Can anyone throw any insight/guidance on this please ?
I know a work around would be just to -127 from the values being sent .... but i'd prefer a clean solution than a workaround if possible.
Many Thanks
Simon
Code below shows the successful implimentation (it compiles)
However, changing either array (trash or buffer) to a BYTE data type, casuses compilation to fail
Code:
  char trash[64];      // local buffer to collect any erroneous data before SOP
  char buffer[2];      // local buffer to collect Packet data
  int flag = 0;          // miscellaneous int for debug purpose
  if(Serial.available()==0){                      // Do nothing if there is no data to read
    goto esc;
  memset(buffer,0,sizeof(buffer));          // Ensure no old data remains from previous loop
  memset(trash,0,sizeof(trash));
  flag = Serial.readBytesUntil('>', trash, 64);  // get to start of packet (SOP)  ::  NB: Termination Char is not put into local buffer(trash), but IS removed from serial buffer.
  flag = Serial.readBytesUntil('<', buffer, 2);  // read until end of packet (EOP)
  while(Serial.available()){ // clear serial buffer of any remaining values
    Serial.read();
esc:
  delay(20);
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
    goto esc;
If there is serial data to read, do it. Get rid of the stupid goto and label.
Code:
A hoarder, huh? Why do you need to save trash?
char and byte are the same size. The Serial methods make no attempt to interpret the data. So, if the function is defined to take an array of chars, and you are sending an array of bytes (containing values in the 0 to 255 range), create a byte array and use a cast in the call to readBytesUntil().
Logged
UK
Offline Offline
Newbie
View Profile
Thanks Paul
(I think) ...
Quote
Would you mind illustrating just how I do that ?
Unless I am misinterpreting what you are saying...I'm at a loss to see !?
On a more fundamental point:
 you say  'function is defined to take an array of chars'        ..... and this is the whole issue.
According to the Arduino documentation (previosuly quoted), it implies that the function is defined to take an array of chars OR bytes.
As to the other points,
What is the difference between :
 If(Serial.read()>0){ << do stuff >> }
and
 if(Serial.available()==0){goto esc; }
<< do stuff >>
esc:
They do exaclty the same thing ?
Hoarding ?
I want to hard this data to study why there is any trash in the first place.
It will be removed when I have finished my 'learning'.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Code:
byte trash[64];
Serial.readBytesUntil('<', (char *)trash, 64);
Quote
Bitch about this in the Website and Forum section, not here. All that means to me is that I can use either a byte array or a char array to hold the data. It does not tell me that the method is overloaded to accept either type, although I can see how you would get that impression.
Quote
and
<< do stuff >>
esc:
They do, except that one does it in a way that looks like you know what you are doing, and the other looks a workaround for faulty logic.
Logged
UK
Offline Offline
Newbie
View Profile
Paul,
Wonderful, thank you so much, your code works and I can now get my full range smiley
I am fairly sure that I would not be able to do that in some other languages, so it has quite suprised me and I will look into the inner workings after this !
As for the 'goto lable' business :  personal preference.
I am less concerned with what it 'looks like' to others, than how it 'feels' for me whilst I am coding.
Bracketed sections are essential in many situations, but sometomes I feel they just add clutter.
But that's just me.
Logged
UK
Offline Offline
Tesla Member
View Profile
This is a problem with the Arduino documentation in general. It describes the API textually but does not tell you the actual signature of the method(s).
Logged
Pages: [1]   Go Up
Print
Jump to:
