Author Topic: Webserver with dyn DNS  (Read 435 times)
Germany
Hello,
to reach my Arduino webserver in the www without knowing my IP address, I used a dyndns service (no-ip in my case) and I know that my ISP will assign my a new IP regularly when I switch off and then on my router again (reset) because then I reconnect.
My question is: Does my ISP also assign me a new IP  if I always let my router on?
Then I would not need to update my IP with the so called DUC (dynamic update client) tool.
Thank you
using Arduino Uno Rev 3
Seattle, WA USA
Seattle, WA USA
Wouldn't this be better answered by your ISP?
Generally, though, the answer is yes. I never turn my router off, and it gets a new IP address about once a week.
Germany
Ok, thank you.
I will monitor the behaviour as from now.
Maybe I have some chanches making the arduino ethernet (as a client ) doing the request to update the new ip.
If someone is interested in this, too, there is an API http://www.noip.com/integrate/request
Can the Ethernet be Client and Server on the same time?
Will I first have to stop the server then start the client then do the update, then stop the client and restart the server (?)
« Last Edit: February 02, 2013, 11:01:25 am by karlok » Logged
Seattle, WA USA
Seattle, WA USA
Yes.
No.
Germany
Ok, thanks.
Now I am trying to use the API described here http://www.noip.com/integrate/request
// NO-IP, Dynamic Update Client, 02.FEB.13
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "dynupdate.no-ip.com";
EthernetClient client;
  Serial.println("[NOIP-DUC]\n");
  Serial.println("Getting IP address from DHCP ...");
  if (Ethernet.begin(mac) == 0)
    Serial.println("Failed to configure Ethernet using DHCP !");
    while (1)
  Serial.print("My IP address: ");
  Serial.println(Ethernet.localIP());
  Serial.println();
  Serial.print("Connecting to ");
  Serial.print(server);
  Serial.println(" ...");
  client.connect(server, 80);
  // checking for answer?
  Serial.println("OK. Sending request...\n");
  client.println("GET /nic/update?hostname=mytest.testdomain.com&myip=1.2.3.4 HTTP/1.0");
  client.println("Host: dynupdate.no-ip.com");
  client.println("Authorization: Basic base64-encoded-auth-string");
  client.println("User-Agent: Bobs Update Client WindowsXP/1.2 bob@somedomain.com");
  Serial.println("ready?!");
  if (client.available())
    char c = client.read();
    Serial.print(c);
  if (Serial.available())
    char c = Serial.read();
    client.print(c);
  if (!client.connected())
    Serial.println();
    Serial.println("Disconnecting.");
    client.stop();
    while (1);
Why don't I get any answer? It just disconnects after ~5 seconds.
Seattle, WA USA
Seattle, WA USA
You need to show all your serial output.
Your domain isn't mytest.testdomain.com, is it?
Your current IP isn't 1.2.3.4, is it?
Your Base64 encoded authorization string isn't base64-encoded-auth-string, is it?
Germany
After having done more debugging, I realized I cannot even connect to dynupdate.no-ip.com
I use this to check:
  if (client.connect(server, 80))
    Serial.println("Connected.");
    while (client.connected())
      while (client.available())
        Serial.print(c);
    client.stop();
    Serial.println("Error connecting!");
My code:
#include <SPI.h>
byte mac[] =
    while (1)
  //Give some time to initialize:
  delay(2000);
  Serial.println();
        Serial.print(c);
    client.stop();
  if (client.available()) // this cannot be reached by now
    Serial.print(c);
    client.print(c);
    Serial.println();
    client.stop();
    while (1)
Serial output
[NOIP-DUC]
My IP address: 192.168.2.124
Connecting to dynupdate.no-ip.com ...
Error connecting!
Disconnecting.
Seattle, WA USA
Seattle, WA USA
Can you connect to other servers?
Germany
Yes, and I tried using http prefix
char server[] = "http://dynupdate.no-ip.com";
and then the output is
[NOIP-DUC]
Connecting to http://dynupdate.no-ip.com ...
Connected.
Disconnecting.
« Last Edit: February 02, 2013, 12:05:05 pm by karlok » Logged
Germany
The prefix http:// should be omitted.
And I found on this forums, the issue has been already discussed and here is the solution
http://arduino.cc/forum/index.php/topic,95456.msg720162.html#msg720162
My problem was that I did not always use the same MAC address so that my router had too many ones to save and it is restricted to grant internet access to only the first 5 ones connected or kind of similiar, so I had to flush this and it worked again.
« Last Edit: February 02, 2013, 12:55:01 pm by karlok » Logged
Online Online
Make sure you use your no-ip email address as the no-ip username and the domain you are using (yourhost.no-ip.org is in the example, but my account is .com instead of .org). I tested the code in the posted link with my changes and got the expected response for my no-ip account.
put in key search words,
Germany
Now it works!
( my account was .org )
Both using my email address and my user name worked (as the no-ip username)
The answer is "nochg <ipaddr>"
Germany
I also implemented parsing the result, i.e. getting the Date and the Message:
    String  buf = "";
    String  msg = "";
    boolean tak = false;
        //Serial.print(c); // verbose?
        buf += c;
        if (tak)
          msg = buf;
        if (c == 10)
          buf.trim();
          if (buf.indexOf("Date:") == 0)
            Serial.println("DATE = " + buf);
          if (buf == "") //empty line -> message
            tak = true;
          buf = "";
    client.stop();
    msg.trim();
    Serial.println("MESSAGE = " + msg);
