Topic: ppm (sum) in to servo output, possible timer issue (Read 126674 times) previous topic - next topic
cardboardboks
Seeing as your online now I'll grab my arduino and see if I cant get it sorted
cardboardboks
And a FAQ would be great help. This is the only code I've come across to deal with both ppm in and servo out and would be a benefit to many people I imagine
DuaneB
Internally its nice code, it just has a bit of an awkward interface to get started. Let me know how you get on
Duane.
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
cardboardboks
Also where in the code can I chuck a set of serial.prints so I can confirm the inputs are correct, its very much hot and miss with just a servo plugged in atm? In uS would be good.
cardboardboks
I also edited a post on the previous page, I think you may have missed it.
"Edit: 1 bit of clarification. I have changed that lump of code to this
#define RC_CHANNEL_IN_COUNT 8
// two ticks per us, 3000 us * 2 ticks = 6000 minimum frame space
#define MINIMUM_FRAME_SPACE 16000
#define MAXIMUM_PULSE_SPACE 5000
Does MAXIMUM_PULSE_SPACE need to be changed as well?
DuaneB
Whenever a channel reads as not 0 it has a valid value -
Code: [Select]
  uint16_t unThrottleIn =  CRCArduinoPPMChannels::getChannel(SERVO_THROTTLE);
  // Test if its something other than zero, if so its valid and we can use it
  if(unThrottleIn)
    CRCArduinoFastServos::writeMicroseconds(SERVO_THROTTLE,unThrottleIn);
    // Add a serial print here
    Serial.println(unThrottleIn);
Duane B
Read this
then watch this
DuaneB
As for the other defines, leave them as they are -
#define MINIMUM_FRAME_SPACE 6000
I notice you have
It should be
As per the original code.
The background is Timer1 is running at 2 ticks per microsecond, with 8 channels you have
8*2,000us = 16,000us
16,000 us in timer ticks = 32,000
Then we have a total frame size of 1/50 = 20,000 us or 40,000 ticks
40,000 ticks - 32,000 signal space = 8,000 frame space
so for 8 channels we expect around 8,000 ticks of frame space, the default setting is 6,000 so we are good for 8 channels or less with the default setting.
Duane
Read this
then watch this
retrolefty
Quote
I notice you have
It should be
LOL, I must be blind, I don't see the difference?
Lefty
cardboardboks
Ok ppm input is looking good now, servo output still very jerky. getting there though
DuaneB
Ok, for the servos are you using the test sketch in its original form or have you made any changes to the sketch of library so far ?
We will need to make some changes for the number of servos, but if possible lets start with the original
Duane
Read this
then watch this
cardboardboks
Just the updated sketch from your website and unmodified library files except the RC_CHANNEL_IN_COUNT
DuaneB
   I can't see any software reason for jerky servos, can you confirm that the servo is attached to the same pin that you are printing the channel input for ? and that the channel input is steady ?
If so, how are you powering the servo ?
Duane B
Read this
then watch this
cardboardboks
that was my bad, I had changed #define RC_CHANNEL_OUT_COUNT and hadn't set it back to 4.
It is working now. Last thing, add more servo outputs..
DuaneB
I have to turn in for the evening now, tomorrow I will add additional comments to the example code to show how and where to add additional servos. Its been good to work through it with someone, it really does need better documentation which I will put together over the weekend.
Duane B
Read this
then watch this
cardboardboks
I know that felling and thankyou for your help.
I'll keep on playing around with the code and keep an eye out for your updated sample code.
