Topic: Error(s) preventing return to loop when code added (Read 967 times) previous topic - next topic
fanuch
I substituted my multi array with a single array and the code works,
These are the variables and the specific lines of code.
Declaired variables:
Code: [Select]
int melodyArray[10] = { 0 };            //Temp array for melody for music playback
int noteDurationArray[10] = { 0 };      //Temp array for duration of notes for music playback
Respective line of code:
Code: [Select]
int noteDuration = 1000/noteDurationArray[thisNote];
tone(10, melodyArray[thisNote],noteDuration);
Substituted with functional variables:
Code: [Select]
int melody[] = {
  NOTE_F4, NOTE_E4, NOTE_D4, NOTE_CS4, NOTE_AS3, NOTE_C4, NOTE_D4, NOTE_D4};
int noteDurations[] = {  4, 4, 4, 4, 4, 4, 3, 2, 4 };
Substituted with functional lines of code:
Code: [Select]
int noteDuration = 1000/noteDurations[thisNote];
tone(10, melody[thisNote],noteDuration);
That's as narrow down to the root of the problem I can ascertain.
Any thing out of the ordinary or problematic?
fanuch
Anyone who was following or cares, the problem was that it was dividing 1000 by 0 which caused it to go crazy and paradoxical. Added a simple
Code: [Select]
break command if the denominator is 0. Solved...
UKHeliBob
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
fanuch
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
