Topic: Controlling LED With Web Server Buttons (Read 5004 times) previous topic - next topic
JackSac67
Having trouble getting this to function correctly. I have an Arduino with an Ethernet Shield hosting a web server that has two buttons controlling the high or low state of an LED. The page loads fine with the "On" button and the "Off" button using POST, but whenever I press either they don't work. Here's my code, anyone happen see the problem?
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x50, 0x9A };
byte ip[] = { 10,0,1,8 };
const int MAX_PAGENAME_LEN = 8;   //Max number of characters for page name
char buffer[MAX_PAGENAME_LEN+1];   //Max number of characters + terminating null is the buffer
EthernetServer server(8010);
 Ethernet.begin(mac, ip);
 server.begin();
 delay(2000);
 if (client) {
   int type = 0;
   while (client.connected()) {
     if (client.available()) {
       memset(buffer, 0, sizeof(buffer));  //clear the buffer
       if (client.find("/")) {
         if (client.readBytesUntil('/', buffer, sizeof(buffer))) {
           Serial.println(buffer);
           if (strcmp(buffer, "POST ") == 0) {  //find the start of the posted form
             client.find("\n\r");  //skip to the body
             while(client.findUntil("pinD", "\n\r")) {  //find string starting with "pin", stop on first blank line
               int pin = client.parseInt();   //the number after "pinD" is the pin number
               int val = client.parseInt();   //the number after the pin number is its value (1 or 0)
               pinMode(pin, OUTPUT);
               digitalWrite(pin, val);
           sendHeader(client, "Post example");   //send a standard header, set up both buttons with POST
           client.println("<h2>Press button to control LED</h2>");
           client.print("<form action='/' method='POST'><p><input type='hidden' name='pinD8'");
           client.println(" value='1'><input type='submit' value='On'/></form>");
           client.println(" value='0'><input type='submit' value='Off'/></form>");
           client.println("</body></html>");
           client.stop();
         break;
     delay(1);
     client.stop();
void sendHeader(EthernetClient client, char *title) {   //standard HTTP header
 client.println();
 client.print("<html><head><title>");
 client.print(title);
 client.println("</title><body>");
tulipman
Hi there,
Where do you specify the pin number??
When I open the serial monitor, I only see 'HTTP' transmitted..
Greetz
Robbert
73 de Robbert / PA3BKL
PaulS
Why do you have multiple forms? Both buttons should be on the same form. If you give the buttons names, you don't need the hidden fields with names.
Why do you want to POST the reply, rather than use GET?
zoomkat
Simple web control page code.
//zoomkat 4-1-12
//simple button GET for servo and pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html, or use ' instead of "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  myservo.write(90); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  //enable serial data print
  Serial.println("server servo/pin 5 test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href=\"/?on\">ON</a>");
          client.println("<a href=\"/?off\">OFF</a>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            myservo.write(40);
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            myservo.write(140);
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Muammar09
IF I wan Turn On / OFF led should I do with Routers???
Please give me project turn on LED with WEB .
