Loading...
Pages: [1] 2   Go Down
Author Topic: Why does Hex not read out in an array for LED "clock"?  (Read 376 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hey everyone,
I was just wondering how hexadecimal is handled in arrays. It doesn't seem to handle them like I would have thought and there doesn't seem to be much on this topic. So I've got a simple 4 led row setup. In my array I have binary "data[](0,0,0,0....1,1,1,1) counting up. When I try to replace the binary with hex "data[](0x0,0x1,0x2,0x3)" i've already tried them as 0x00,0x01... and I can't seem to figure it out. The code is below. I'd just much rather be using Hex to store in memory rather than binary because I'm working on just making my own POV.
Code:
int pins[] = {9,10,11,12}; // an array of pin numbers
int col_len = 4; // column lenght
// customizable parameters
int timer1 = 1000; // time between columns
int timer2 = 0; // time between frames
int timer3 = 0; // time between drawings
int frame_len = 4; // frame length
int frame_num = 1; // number of frames
// data corresponding to the image to be displayed
int data[] = {0x0,0x1,0x2,0x3,0x4,0x5,0x6,0x7,0x8,0x9,0xA,0xB,0xC,0xD,0xE,0xF};
int i;
for (i = 0; i < col_len; i++)
pinMode(pins[i], OUTPUT); // set each pin as an output
int a,b,c;
// go through all data for all columns in each frame.
for (a = 0; a < frame_num; a++)
for (b = 0; b < frame_len; b++)
for (c = 0; c < col_len; c++)
if (data[a*frame_len*col_len + b*col_len + c] == 0) {digitalWrite(pins[c], LOW);}
else {digitalWrite(pins[c], HIGH);}
delay(timer1);
delay(timer2);
delay(timer3);
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
I don't know why hex is not working for you but I don't understand why you want to use it.  When I was playing with POV I much preferred binary because it allowed me to visualise what I would output much better than hex would have done.
Incidentally this tests the values in the array and proves that they are correct
Code:
int data[] = {
  for (int i=0;i<=15;i++)
    Serial.print(i);
    Serial.print("\t");
    Serial.print(data[i],DEC);
    Serial.print("\t");
    Serial.print(data[i],BIN);
    Serial.print("\t");
    Serial.println(data[i],HEX);
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
You need to tell us what your expectations were, and how what you observed differs from that.
Code:
That data is in decimal, and doesn't really count up.
« Last Edit: February 02, 2013, 02:43:06 pm by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
And I would say exactly the opposite, it is easy to visualise a pattern when it is in hex, but difficult in binary because there is so many digits it is much harder to see the pattern.
OP
Quote
then you say
Quote
These are not the same, to put that latter array into binary you need
data[] = { B00000000, B00000001, B00000010, B00000011 ....
Logged
Des Moines, WA - USA
Offline Offline
God Member
View Profile
I suspect your mental model of number representations, arrays and their initialization values may be off.
Your best bet is to explains what you are trying to do and possible why you think it needs to be done some way you got in your head.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Alright, lets get some questions taken care of.
The lights (4 Leds) are by no means in order, I've written the binary down and it makes no sense. It appears random. The only solid thing I'm seeing is 0x8 every other clock cycle.
Code:
Quote
then you say
Quote
I did not realize that if I was to place "B" it would represent a Byte. I was simply putting a single string of binary in and have it segmented by "col_len" so when I have
Code:
int data[] = {0,0,0,0,0,0,0,1,0,0,1,0,0,0,1,1,0,1,0,0,0,1,0,1,0,1,1,0,0,1,1,1,1,0,0,0,1,0,0,1,1,0,1,0,1,0,1,1,1,1,0,0,1,1,0,1,1,1,1,0,1,1,1,1};
One of the if loops (last one using variable c in it) cuts up the array into 4 bit chunks. So if you look at it in 4 bit segments, you see the count up from 0000 to 1111.
Maybe I'm making the wrong assumption, but I like hex more and thought it'd be easier to code especially when long term this POV will be interacting w/ an external memory for larger storage.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
My idea is to have a POV device (just really for learning purposes) that will use anywhere from 16-32 LEDs. When dealing with this many, I figured that I'd probably be best to deal (coding) with hex so rather than punching in a 32 bit binary for a single "column", I could simple type in something like 0xFF. I also figured that it would be easier using hex when interacting w/ an external memory (EEPROM) or something of the sort. Mostly I was thinking hex for coding purposes to easily wrap my mind around what's going on.
I didn't realize I'd run into this issue right off the bat. I really don't understand why storing a hex in an array would be such a problem. Am I going about the wrong way displaying the hex data? Does the arduion array not interpret it and sent it out the outputs like it does the raw binary?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
So when substituting hex for your sort of binary you must change your code as well.
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
And so you can (the leading 24bits would be padded with zeroes in this case).
Hex or binary (or octal or decimal), the compiler doesn't care, they're all just a convenience and all end up as binary.
Logged
Offline Offline
God Member
View Profile
Can you read this image?
Code:
uint8_t image[] =
  0b00000000
, 0b11111111
, 0b00010000
, 0b11111111
, 0b00000000
, 0b11111111
, 0b10010001
, 0b10010001
, 0b00000000
, 0b11111111
, 0b10000000
, 0b10000000
, 0b00000000
, 0b11111111
, 0b10000000
, 0b10000000
, 0b00000000
, 0b11111111
, 0b10000001
, 0b11111111
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
I was initially following a blog post tut with that code, but now that I look at it more and with some of the help from you guys... I see that just isn't what I'm looking for. Pretty inefficient now that I look at it.
« Last Edit: February 02, 2013, 03:40:21 pm by Drewski » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Code:
uint8_t image[] =
  0b00000000
, 0b11111111
, 0b00010000
, 0b11111111
, 0b00000000
, 0b11111111
, 0b10010001
, 0b10010001
, 0b00000000
, 0b11111111
, 0b10000000
, 0b10000000
, 0b00000000
, 0b11111111
, 0b10000000
, 0b10000000
, 0b00000000
, 0b11111111
, 0b10000001
, 0b11111111
Of course I can. I see your point, but when you're putting that out in 32 bits length rather than 8, that's a lot of typing. Plus, I'm going to try coding up a simple GUI to handle the text -> hex for me, so I wont be hand coding it.
Logged
East Anglia (UK)
Offline Offline
Edison Member
View Profile
Quote
Each to their own but I know which of these 2 I can see a pattern in
Code:
byte BinPattern[]=
 B11100000,
 B01110000,
 B00111000,
 B00011100,
 B00001110,
 B00000111
byte HexPattern[]=
0xE0,
0x70,
0x38,
0x1C,
0x0E,
0x07,
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
Code:
byte BinPattern[]=
 B11100000,
 B01110000,
 B00111000,
 B00011100,
 B00001110,
 B00000111
byte HexPattern[]=
0xE0,
0x70,
0x38,
0x1C,
0x0E,
0x07,
Kind of stumped as to how to handle either a hex or byte and convert that to be displayed on proper led. So I've got the following arrary for the LEDs with a ledpin count.
Code:
int pinCount = 4;
int data[] = {B0000,B0001,B0010,B0011};  // array of data
Idea being the data set would be larger to walk through all 4 leds rather than just the first two. So what I guess I'm asking is how can you walk through the byte in the data array? I get how to walk through the data array (a simple for statement) but once you have accessed that byte, say the last B0011 (data[3]), how can each bit be assigned to an led?
Logged
Offline Offline
God Member
View Profile
Which bit of 'B0011' corresponds to say pin 9.  Bits are numbered with 0 on the right thru 3 on the left just the right side of the 'B'
Code:
int pinCount = 4;
Logged
Pages: [1] 2   Go Up
Print
Jump to:
