Loading...
Pages: [1]   Go Down
Author Topic: Problem communicating with a BlueSMIRF bluetooth + arduino  (Read 79 times)
Offline Offline
Newbie
View Profile
hello!!
I'm trying to connect an arduino mega width a BlueSMIRF-Silver.
I already detected my bluetooht on my pc, and I uploaded a simply test program to my arduino.
the problem comes when I'm trying to send data using the bluetooth as a serial COM port (is a COM11).
This is the software does im using:
CODE:
//import class to set up serial connection with wiring board
import processing.serial.*;
Serial port;
//button setup
color currentcolor;
RectButton rect1, rect2;
boolean locked = false;
  //set up window
  size(200, 200);
  color baseColor = color(102, 102, 102);
  currentcolor = baseColor;
  // List all the available serial ports in the output pane.
  // You will need to choose the port that the Wiring board is
  // connected to from this list. The first port in the list is
  // port #0 and the third port in the list is port #2.
  println(Serial.list());
  // Open the port that the Wiring board is connected to (in this case 1
  // which is the second open port in the array)
  // Make sure to open the port at the same speed Wiring is using (9600bps)
  port = new Serial(this, Serial.list()[0], 9600);
  // Define and create rectangle button #1
  int x = 30;
  int y = 100;
  int size = 50;
  color buttoncolor = color(153, 102, 102);
  color highlight = color(102, 51, 51);
  rect1 = new RectButton(x, y, size, buttoncolor, highlight);
  // Define and create rectangle button #2
  x = 90;
  y = 100;
  size = 50;
  buttoncolor = color(153, 153, 153);
  highlight = color(102, 102, 102);
  rect2 = new RectButton(x, y, size, buttoncolor, highlight);
void draw() {
  background(currentcolor);
  stroke(255);
  update(mouseX, mouseY);
  rect1.display();
  rect2.display();
void update(int x, int y) {
  if(locked == false) {
    rect1.update();
    rect2.update();
    locked = false;
  //Turn LED on and off if buttons pressed where
  //H = on (high) and L = off (low)
  if(mousePressed) {
    if(rect1.pressed()) {            //ON button
      currentcolor = rect1.basecolor;
      port.write('H');
    } else if(rect2.pressed()) {    //OFF button
      currentcolor = rect2.basecolor;
      port.write('L');
class Button {
  int x, y;
  int size;
  color basecolor, highlightcolor;
  color currentcolor;
  boolean over = false;
  boolean pressed = false;
  void update()
    if(over()) {
      currentcolor = highlightcolor;
      currentcolor = basecolor;
  boolean pressed()
    if(over) {
      locked = true;
      return true;
      locked = false;
      return false;
  boolean over()
    return true;
  void display()
class RectButton extends Button {
  RectButton(int ix, int iy, int isize, color icolor, color ihighlight)
    x = ix;
    y = iy;
    size = isize;
    basecolor = icolor;
    highlightcolor = ihighlight;
  boolean over()
    if( overRect(x, y, size, size) ) {
      over = true;
      return true;
      over = false;
      return false;
  void display()
    stroke(255);
    fill(currentcolor);
    rect(x, y, size, size);
boolean overRect(int x, int y, int width, int height) {
  if (mouseX >= x && mouseX <= x+width &&
      mouseY >= y && mouseY <= y+height) {
    return true;
    return false;
I know i have to check which is the COM11 in the array, but for see the list of COM's i need this line:
...but when I try to run the program, i see this message: "import does not name a type" ; making reference to this one: "import processing.serial.*;"   smiley-roll
« Last Edit: February 02, 2013, 02:21:43 pm by Jair » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
"Hi. I've got some Fortran code that my C++ compiler doesn't like. Why?"
That is a Processing sketch that you have posted. No wonder the Arduino IDE can't compile it.
Logged
Pages: [1]   Go Up
Print
Jump to:
