Loading...
Pages: 1 [2]   Go Down
Author Topic: SRAM interface question  (Read 317 times)
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
My C++ is very rusty to non-existent but I reckon you could create a class with an internal data structure as required, then overload the = operator with code that read/writes to the external RAM so at the source level it almost looks like normal code. Like
XM.some_var = 1234;
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Melbourne, Australia
Offline Offline
Full Member
View Profile
XM.some_var = 1234;
______
Rob
The variable would have to know where free space was, and once used, return it to free space. An array of such variable might help with that.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Yes, I'm assuming static data so knowing where free space is would not be an issue.
A "variable" could use offsetof() to determine it's location in the struct and therefore the XM, but this approach would need functions for the various variable types and I don't know how you would differentiate between variables of the same type.
It would get very messy I think unless a C++ guru can advise otherwise.
Certainly an array of same types would be a lot easier.
And of course if you can fit the struct in internal RAM there's little point in having the external RAM in the first place smiley
______
Rob
Logged
Offline Offline
Jr. Member
View Profile
Between oric_dan and aarondc's comments (thank you both) I've been able to get the following to work:
Code:
 for(int i=0; i<7; i++) {
    unsigned int rw_addr = exIntAry0+(i*sizeof(int));
    writeRamInt(i, rw_addr, sizeof(int));
    int numb = readRamInt(rw_addr, sizeof(int));
    Serial.print(F("numb= "));
    Serial.println(numb);
The problem is, you have to program how many elements the array has...  ...any ideas on how to solve this issue?
« Last Edit: May 24, 2013, 10:49:20 pm by sparkfuntoday » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
