Pages: [1] 2 3   Go Down
Author Topic: Capacitive Sensor No Output  (Read 713 times)
Singapore
Recently I purchased a set of capacitive sensors for my project, received them today and ran their sample code provided, but am not getting any output at the 'serial window' when the sensors are been toggled by my fingers. Sensors and program are in the following link and please advice if anything is wrong with the code or possible reason that could have caused no output from breakout board (MPR121) to Arduino Uno.
http://www.dfrobot.com/wiki/index.php?title=Capacitive_Touch_Kit_For_Arduino(SKU:DFR0129)
« Last Edit: February 02, 2013, 02:29:33 pm by xaviergoh » Logged
Miami/Florida
Broken link for me. Can't access.
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
His link, http://www.dfrobot.com/wiki/index.php?title=Capacitive_Touch_Kit_For_Arduino(SKU:DFR0129)
Which one are you doing? No code, no help, otherwise were just guessing.
« Last Edit: February 02, 2013, 02:47:26 pm by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Singapore
Hi HazardsMind,
Thanks for replying to my post, I tried the code that they suggest at the webpage for the keypad.
 TouchWheel.pde
 MPR121 WhellPad Example Code
 by:Waiman Zhao
 Mail:Binpower@foxmail.com
 created on: 11/2/14
 license: CC-SA 3.0
 Hardware: 3.3V Arduino Pro Mini
           SDA -> A4
           SCL -> A5
           IRQ -> D2
#include <Wire.h>
#include <mpr121.h>
int key = 0;
// =========  setup  =========
    //  initialize function
  Serial.begin(19200);
  Wire.begin();
  CapaTouch.begin();
  Serial.println("START");
// =========  loop  =========
  key=CapaTouch.keyPad();
  if (key==11)
  { Serial.print("key:");
  Serial.println("*");
  else if(key==12)
  Serial.println("#");
  else if(key>0){
    Serial.println(key);
    delay(200);
It doesnt have any output at the serial window after I added the library and flashed the Uno. I am a novice in Arduino, I am not sure whether do I need any additional code for it to have an output at the serial window. Please advice
Central MN, USA
Does the serial output show the word START?
Queens, New York
Did you by any chance set the baud rate in the actual serial monitor screen? In the bottom right corner, the default is 9600.
Singapore
http://postimage.org/image/6bygyc3zz/ <-- my output. only one logo after initialised, and nothing i do will add anything else to the output.
Anything I need to do other than the codes above? basically I connected the boards up as shown in the seller's page and uses their code to flash. Not sure whether i missed out anything.
Greatly appreciate the help given.
« Last Edit: February 03, 2013, 01:20:03 pm by xaviergoh » Logged
Queens, New York
Your baud rate in the serial monitor says 300 baud, that is wrong! It should be 19200, not 300.
« Last Edit: February 03, 2013, 01:56:59 pm by HazardsMind » Logged
Central MN, USA
Follow HazardsMind's reply and set correct baud rate.
Singapore
Hi guys, I tried different baud rate, it shows "START", but still doesnt get any output from the sensors.
Queens, New York
Ok, great, you got START. Now do a serial print of just "key" and see what values you get for each number pressed.
Singapore
Thanks for suggestion. I tried the following, not sure if it's what u meant. None of the keys give an output to the serial window still.
Queens, New York
It should be outputting atleast "key" try just Serial.println(key); right after key=CapaTouch.keyPad();
Singapore
with Serial.println(key), I get endless "-1"....
with Serial.println("key"), I get endless "key"...
« Last Edit: February 04, 2013, 01:31:08 pm by xaviergoh » Logged
Queens, New York
Ok then check your wiring. Your getting something now, but its not what you want, so check your wiring for errors.
Pages: [1] 2 3   Go Up
