Loading...
Pages: [1]   Go Down
Author Topic: Please help me find a motor and speed controller.  (Read 307 times)
U.S.A
Offline Offline
Newbie
View Profile
I am working on a project which will need an as small as possible DC motor which will spin up to 2500 RPM with a little bit of weight on it, maybe a pound. I don't know a ton about how to pick out the right motor and will need a speed controller too so that I can control this setup with my Arduino. Thanks.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Motor load is a torque, not a weight - you'll have to explain more about the mechanics of the
situation or work out the torque yourself.  If none of this means anything then just provide
more information about the setup please?!
Logged
U.S.A
Offline Offline
Newbie
View Profile
It is for a centrifuge. I am planning on attaching a plastic disc directly to the motor shaft.
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
It's aaaaaages since I did this kind of calculation, but the torque T required depends on the Moment of Inertia I of the disk and the required acceleration a, and :
T = Ia
The Moment of Inertia of a disk on mass m and radius r is
I= mr2 / 2
(Let's check those units....
units of I will be kg m2
units of a are rad / s2 or just 1/s2
So units of T are kg m2 / s2
(Which is right since T=Fd and units of force at kg m / s2) )
I think... it's been a long time, as I say
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Offline Offline
Full Member
View Profile
I believe you'll want to know the horsepower of the motor.
Logged
peace*&^
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Power in Watts is just P = Tw where w (lower case omega) = rotation speed in rads / sec
Logged
IT Crowd:
Pages: [1]   Go Up
Print
Jump to:
