Topic: Wishing my Tamiya Motors Had More Drive (Read 2609 times) previous topic - next topic
encryptor
I built a rc car, but after completing it only does well on solid surfaces, not carpet.  Further it will only go fwd/reverse and not left/right because it would be dragging the back wheels.  This is a double gear box, so for left/right I have each wheel go in opposite direction.  However it only seems like it would do it if I had 2 double gear boxes making it truly 4 wheel drive.  Even without this bulky 6v lantern battery and using a 12v adapter cable I noticed my car is very weak.  Unless I replace the Tamiya motors with something bigger might this work better.  here's a pic.  I control it via bluetooth commands. F= forward, B=reverse, L=left, R=right.  what's your thoughts?  I'm thinking success on proving I can control hardware via bluetooth, but failure in hardware's capability meant for a prototype car.
peace*&^
Chagrin
I would suggest verifying that you're getting as much amperage through your motors as you think you're getting (use an ammeter). Is the L298 getting hot?
Next step would be showing us how you have it wired up.
encryptor
The program works with the wheels turning the way I expect them to.  Here is my code:
Evan Johnson
Description: test sending serial input to turn on 1 of 3 leds.
char serInStr[30];  // array that will hold the serial input string
//int breakLed = 2;
//int reverseLed = 4;
  //Setup led for something to monitor working status
  //pinMode(led, OUTPUT);
  //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
  //Setup Channel B
  pinMode(13, OUTPUT); //Initiates Motor Channel A pin
  pinMode(8, OUTPUT);  //Initiates Brake Channel A pin
  //Start the UART TX1/RX0 (D1/D0) communication at defined rate
  //Call menu function
  menu();
  for(int i=0; i<4; i++)
    digitalWrite(led, HIGH);
    delay(200);
    digitalWrite(led, LOW);
    delay(200);
  //read the serial port and create a string out of what you read
  if(readSerialString())
    Serial.println(serInStr);
    char cmd = serInStr[0];
    int num = atoi(serInStr+1);
    if( cmd == 'F' )
      Serial.println("MADE IT IN F");
      //Motor A and Motor B engage breaks
      digitalWrite(9, HIGH); // ENGAGE BREAK ON CHANNEL A MOTOR
      digitalWrite(8, HIGH); // ENGAGE BREAK ON CHANNEL B MOTOR
      //Motor A forward @ half speed
      digitalWrite(12, HIGH); //Establish forward direction of channel A
      digitalWrite(9, LOW);   //Disengage the brake for channel A
      analogWrite(3, 255);   //Spins the motor on channel A at half speed
      //Motor B forward @ half speed
      digitalWrite(13, HIGH);  //Establishes forward direction of Channel B
      digitalWrite(8, LOW);   //Disengage the Brake for Channel B
      analogWrite(11, 255);    //Spins the motor on Channel B at half speed
    else if( cmd == 'B' )
      Serial.println("MADE IT IN B");
      //Motor A background @ half speed
      digitalWrite(12, LOW); //Establish forward direction of channel A
      //Motor B background @ half speed
      digitalWrite(13, LOW);  //Establishes forward direction of Channel B
    else if( cmd == 'L' )
      Serial.println("MADE IT IN L");
      //Motor A backward @ half speed
      digitalWrite(12, LOW); //Establish backward direction of channel A
    else if( cmd == 'R' )
      Serial.println("MADE IT IN R");
      //Motor B backward @ half speed
      digitalWrite(13, LOW);  //Establishes backward direction of Channel B
    else if( cmd == 'S' )
      Serial.println("MADE IT IN S");
      Serial.println("Invalid Selection. Please try again!");
      return;
  delay(2);
//1) Menu void/void function
void menu()
  Serial.print("\r\nEvan's Double Gearbox Control!\n"
                  "'F' for forwards\n"
                  "'B' for backwards\n"
                  "'L' for left\n"
                  "'R' for right\n"
                  "'S' for stop\n"
                  "Please enter your command: ");
//2) Read a string from the serial and store it in an array
//you must supply the array variable
uint8_t readSerialString()
  if(!Serial.available())
    return 0;
  delay(10);  // wait a little for serial data
  int i = 0;
  while (Serial.available())
    serInStr[i] = Serial.read();   // FIXME: doesn't check buffer overrun
    i++;
  serInStr[i] = 0;  // indicate end of read string
  return i;  // return number of chars read
I only have a multimeter.  Nothing is getting too hot.  Once the wheels touch the ground it barely moves.  You're right I'm probably not getting enough amperage.  I hear an amp meter to test.  How can I increase amperage?
peace*&^
Chagrin
You forgot to set pin 3 and 11 as output.
encryptor
Is it really necessary?  Will that change make a world of a difference in amperage? ^_^
peace*&^
MarkT
#5
Feb 03, 2013, 12:23 am Last Edit: Feb 03, 2013, 12:26 am by MarkT Reason: 1
analogWrite () sets the pin as an OUTPUT, so that's not an issue (although its poor coding style).
We don't know which motors you are using, nor the current ratings of that battery - can you provide links to the
data for the motors and more information (such as manufacturer's datasheet) for the battery?
[ edit: a lattern battery is not a motor battery...  Motors may require a lot of current (but how much
do yours need?)  also which motor shield? ]
encryptor
#6
Feb 03, 2013, 12:50 am Last Edit: Feb 03, 2013, 01:05 am by encryptor Reason: 1
I was using a 12v adaptor cable before I tried the latern battery (6v) with a little better results.  There are two FA-130 motors.  http://www.pololu.com/catalog/product/77
It is the Arduino Motor Shield.  http://store.arduino.cc/ww/index.php?main_page=product_info&cPath=11&products_id=204
Rayovac latern battery.  sorry the site does say how much continuous amperage.  However this is a much heavier alcaline battery so I imagine it can handle these small motors.
http://hdsupplysolutions.com/shop/RecordSearch?catalogId=110076&storeId=10051&langId=-1&rstate=157540-1&parentCategoryId=
I don't know why the car is so weak?  Could I be supplying too much voltage to these motors being that they run on 3v and I'm supplying the barrel jack on Arduino Uno R3 with 12v? :smiley-sweat:
peace*&^
encryptor
how do I supply 3v to these motors if the Arduino Motor shield works on 5v-12v.  Do I need to upgrade the motors?
peace*&^
tawandapro
are you using rechargeable batteries? If you are not that its a 90% chance thats why. i have run motors on rechargeable batteries and non rechargeable batteries and found out that they had more torque on rechargeable batteries.
encryptor
I believe that, but let's forget I'm even running on batteries right now.  I'm using a 12v wallwart into the arduino uno r3, then it goes to the arduino motor r3, which also runs on 5-12v.  So we are cool so far, but then the FA-130 motors run at 1.5amps to 3amps, then will stall out (according to pololu).  I'm thinking I'm overpowering those motors.  What's your opinion? :*
peace*&^
zoomkat
Those motor shields can probably have a significant voltage drop across them. If you have a multimeter you can measure the voltage drop while the motors are operating. also check the battery voltage while the motors are operating to see how low it goes. As the others say, go rechargable, even if just using rechatgable D cells. Saves $$$ and time.
encryptor
I was figuring the lantern battery I bought would give me good lifespan and a decent amperage for $6.  Plus I thought it was kind of funny to use this type of battery in a project.  Ok understood, better amps and saves time.  I have a couple lipo batteries now, but no way to charge them yet.  I have the sparkfun recharge shield but need single male pins infront of jst port.  I have 2 maxim 1811 500mA rechargeable ICs but didn't know it required a SOIC to DIP socket.
Back on subject, I'll measure these voltages.  I believe my only choices are 1)get higher rated motors from Pololu to use with 5v.  2) Get a small breadboard or prototype PCB to connect 3.3v, but even still that's above the 3v being the max.
peace*&^
MarkT
Well the motor shield will drop some volts so that it is probably a reasonable match at 5 or 6V motor supply, but
each motor can take a max of 2A or so - does your supply/battery handle that load?  Those peaks will be needed to
get the thing moving from a standstill more easily.
I think those motors are rather small - some about twice the weight / size might do better (but you'll need to
make sure the supply is adequate).
The gearing is another thing to consider - a great reduction ratio would give more torque but lower theoretical
top speed.  Reducing the weight by using a smaller battery (high current NiMH pack or LiPo 2S perhaps) might
make it easier to propel too...
TeslaIaint
It would be a huge help to get rid of the weight of that lantern battery and to have front wheels that can actually turn instead of dragging on a high friction surface.
michinyon
Making a 4-wheel car turn by spinning one pair of wheels in opposite directions is not going to work.
You need to run the wheels in the same direction,  with one a bit faster than the other.
