Loading...
Pages: [1]   Go Down
Author Topic: Graphic LCD Double text problem  (Read 393 times)
Offline Offline
Newbie
View Profile
Hello, thanks for this great forum !!!
 i'm running a 128x64 Graphic LCD with a Arduino MEGA 2560, and i try to make lines of text display on the screen,
Everything works fine with the demo Program, but with my program everything is displayed 2 times
this is a part of my program.
thanks
Code:
#include <glcd.h>
#include "fonts/Arial14.h"         // proportional font
#include "fonts/SystemFont5x7.h"   // system font
  GLCD.Init();   // initialise the library, non inverted writes pixels onto a clear screen
void loop(){
  GLCD.ClearScreen();
  GLCD.SelectFont(System5x7);
  GLCD.Puts("PROGRAMME");
  GLCD.CursorTo (0 , 1);
  GLCD.Puts ("HEAT V1.06");
  delay (2000);
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
I dont have a solution for you, but I do have a reason
typically the ram in these things is split down the middle of the screen in two banks, seems that your code is sending the same data to both banks of ram, thus double vision
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
It looks like you may have both of your chip selects connected together.
Don
Logged
Offline Offline
Newbie
View Profile
Ok, thanks for reply,
i am agree with you that both chips receiving the same info, but i am sure that CS1 and CS2 are not connected together and it works with the demo program !
Please, do you have other idea ?
Logged
Offline Offline
Faraday Member
View Profile
Quote
... and it works with the demo program
What demo program?
Why is the code to display your (unchanging) message in loop() instead of in setup()?
Don
Logged
Dallas, TX USA
Offline Offline
Edison Member
View Profile
I have seen this issue before, it is more than likely a wiring error.
Run the diag sketch that comes with the library and then look at the trouble shooting
guide in the included documentation for some tips on how to resolve it.
My guess is that the chip selects are mis wired or the connections used on them are not making proper contact.
Floating or mis connected chip selects can create the type of output you are seeing.
The diags will show chip numbers on the display which can help isolate the problem.
Run it and if you are still having issues. Post the text diag output and also describe
what you see when the diag sketch  runs.
--- bill
Logged
Pages: [1]   Go Up
Print
Jump to:
