Loading...
Pages: [1]   Go Down
Author Topic: SM-630 Fingerprint module  (Read 228 times)
Offline Offline
Newbie
View Profile
hey fellas.. i'm currently working on a project and i need to deal with above 500 fingerprints..
i took help from http://tutorial.cytron.com.my/2013/01/29/interfacing-fingerprint-reader-integrated-sm630-with-arduino-uno/ but that tut dealed with 5 finger prints only..
for above 500 prints i tried to use fixed and variable part..
Code:
  byte addFingerPrint[] = {0x4D, 0x58, 0x10, 0x03, 0x40}; // 5  fixed bytes
  byte varyPart[3], highB = 0x00, lowB = 0x00;                  // 3 variable bytes
  int a2;
  varyPart[0]=highB;
  varyPart[1]=lowB;
  varyPart[2]=0x00;
  a2=0;
  while(a2<5){                                                       //while loop to add fixed bytes to checksum i.e. varyPart[2]
    varyPart[2] = varyPart[2] + addFingerPrint[a2];
    a2++;
  a2 = 0;
  while(a2<2){                                                     //while loop to add variable bytes to checksum i.e. varyPart[2]
    varyPart[2] = varyPart[2]+varyPart[a2];
    a2++;
  Serial.write(addFingerPrint, sizeof(addFingerPrint));   // write the 5 fixed bytes array of the command code
  Serial.write(varyPart, sizeof(varyPart));               // write the 3 variable bytes array of the command code
  correctRespond();     //function to check response of sm630
  operationSuccesful();    //function to check succcess of operation
and if operation is successful then lowB++ and highB++
but i m able to add first fingerprint at 0th position only.. then module is not rplying correctly for rest positions.. seems like increment operator is not operating properly..
how could i apply loop to deal with above 500 prints..??
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
I hope you mean:
Code:
lowB++;
if (lowB == 0)
    highB++;
Logged
Offline Offline
Newbie
View Profile
yes..
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Start with some Serial.print()s so you know what your program IS doing.
Logged
Pages: [1]   Go Up
Print
Jump to:
