Pages: 1 [2] 3 4   Go Down
Author Topic: using integer type to define pins, why?  (Read 909 times)
Left Coast, CA (USA)
Measurement changes behavior
Personally I use byte, because pin numbers are indeed unsigned, and don't go over 255.
But does for example analogRead(pin#) function cast it as a int size value inside the function? And as you said a pin number declared as a const anyway doesn't occupy any memory space on it's own, only by the thing that reference it?
Lefty
« Last Edit: February 03, 2013, 12:54:07 am by retrolefty » Logged
Des Moines, WA - USA
Online Online
Actually pin numbers, as used with 'digitalWrite(12, HIGH)', are in fact specified as being of type 'uint8_t' so the compiler will down convert the 'int' to an 'uint8_t' for you.
But technically you should be specifying pins as 'const uint8_t pinANALOG = A0' as an example.
« Last Edit: February 03, 2013, 12:57:07 am by lloyddean » Logged
Ah got it, thank you.
Lefty
Melbourne, Australia
Shannon Member
Lua rocks!
In other words, "const byte".
But of course now I've learned that doesn't save any real space over using const int as applied to pin number use.  smiley-grin
Lefty
Online Online
My problem with 'byte' is it doesn't tell me enough about it.
I believe it is a synonym for 'unsigned char' (because its different on different platforms), but I'm never certain and alway find myself doing the double-check.
I much prefer 'uint8_t' as it's easier to know what you're getting and is the same everywhere I want to be.
Shannon Member
Lua rocks!
That's fine, but the core type is "unsigned char" as shown here in stdint.h:
/** \ingroup avr_stdint
    8-bit unsigned type. */
typedef unsigned char uint8_t;
You just have to remember that "unsigned char" is an 8-bit unsigned type.
Using uint8_t is one typedef away from the core type.
This is obviously a style issue, but for me, I prefer to remember that. It's like saying:
"I want to call a dog a MammalWith2LegsThatBarks because that tells me more about it."
OK, but it's really a dog.
I don't want to start a "style war" here, hey next we'll be arguing about GOTO. smiley-wink
Shannon Member
Lua rocks!
If they have the typedef I quoted. If not, it's an unsigned char.
Hey, wait, I just shot myself in the foot here. I should be using "unsigned char" and not "byte". Oh well.
You own a two legged dog that barks? Post a video or it isn't true.   smiley-grin
Lefty
Shannon Member
Lua rocks!
I was very emotional when I wrote that. smiley
Online Online
Nick - I'm not sure what your getting at or if you're upset or not.
Just saying for me it's ambiguous as to if it's signed or unsigned (unless I look it up) where as 'uint8_t' it's clear that it's unsigned and is unsigned on all platforms where as 'byte' if expressed at all can be either.
Shannon Member
Lua rocks!
I'm only upset that I thought a dog had two legs.
Well they do have two legs, plus two more.  smiley-wink
Temple, Texas
I think many people who know better, sometimes just use int instead, when trying to help someone to whom uint8_t or--even byte--would cause additional confusion.  One can't learn everything at once...
Shannon Member
Lua rocks!
Two legs, squared?
Pages: 1 [2] 3 4   Go Up
