Topic: Problem with ir remote library and pwm pins (Read 873 times) previous topic - next topic
shihtin
Feb 03, 2013, 07:40 am Last Edit: Feb 09, 2013, 09:02 pm by shihtin Reason: 1
Hello,
I am a newbie in arduino. I want to control the brightness of the led using ir remote. But this doesn't work. I am using irremote.h library.
I think the problem is related to timers. What I have to do???
The code is given below..
#include <IRremote.h>
int ir_pin = 3;
int pwm_signal=11;
int value;
int x;
int i = 0;
unsigned long start;
unsigned long stp;
IRrecv irrecv (ir_pin);
decode_results results;
irrecv.enableIRIn();
pinMode(pwm_signal,OUTPUT);
 x = ir_check();
 pwm_write (x);
Serial.println(x);
int ir_check()
 if (irrecv.decode(&results))
   if (results.value==2060 || results.value==12)
     Serial.println("on");
     i++;
   irrecv.resume();
 return i;
void pwm_write (int x)
 if (x<10)
   value = x*24;
  /* digitalWrite(pwm_signal,HIGH);
   delayMicroseconds(value);
   digitalWrite(pwm_signal,LOW);
   delayMicroseconds(1000-value);*/
  analogWrite(pwm_signal,value);
Nick Gammon
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
More info:
shihtin
Thanks for the information... can you give any solution?. I am using arduino dueminalove.
Nick Gammon
What does your debugging display tell you?
Perhaps put in more serial prints to confirm what values you have in your variables.
More info:
shihtin
It work well till first key is pressed on irremote. After that both ir and pwm functions remains in previous condition. I think the problem is related to the timer of the arduino dueminalove. ie, both ir library and analogWrite function uses the same library. I tried to change the timer used in ir library but it can't create any difference.
