Offline
Sr. Member
« on: January 13, 2013, 02:03:02 am » |
Good Morning, Id like to know where i can find the file *.hex after arduino has been compiled or uploaded,
could you help me kindly with this ?
Thanks gnusso
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #1 on: January 13, 2013, 02:23:23 am » |
what os do you use?
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Offline
Sr. Member
« Reply #2 on: January 13, 2013, 02:36:01 am » |
Hi All, I've change the "build.path=/" inside the preferences, and after during the "verify" pushing "shift" during it I've seen that inside the folder is present a file named:
sketchname.cpp.hex
is enough for use normal programmer renaming file "in sketchname.hex" for use "ATMEGA328" with only minimal part ?
Thanks Gnux
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #3 on: January 13, 2013, 02:56:22 am » |
yes, if the target perfectly matches your setup
Logged
Offline
Sr. Member
« Reply #4 on: January 14, 2013, 01:34:30 am » |
Perfect Thanks for the information, Andrea
Logged
Offline
Sr. Member
« Reply #5 on: February 04, 2013, 03:52:32 am » |
and If I would like make file with WIN 7 like operating system which is the procedure ?
thanks gnux
Logged
