Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: NilRTOS - A Fast Tiny Preemptive RTOS  (Read 5690 times)
Rapa Nui
Offline Offline
God Member
Pukao hats cleaning services
View Profile
With the latest:
6ADC channels, 1000usec period:
Code:
Done!
Max Write Latency: 47624 usec
Unused Stack: 53 5354
FIFO record count: 833
Minimum free count: 724
Is it faster or am I doing something wrong? smiley
Yea, I did - almost all ADC data were "0" so the print to file was fast enough..
« Last Edit: February 01, 2013, 03:06:22 pm by pito » Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
pito,
Here is a simple Arduino sketch that logs ADCs as fast as possible with no regard for overruns.
Code:
//Dummy Arduino Logger
#include <SdFat.h>
SdFat sd;
SdFile file;
const uint16_t NREC = 4000;
const uint8_t NADC = 2;
const uint8_t sdChipSelect = SS;
  Serial.println(F("type any character to begin"));
  while (Serial.read() < 0);
  // Initialize SD and create or open and truncate the data file.
  if (!sd.begin(sdChipSelect)
    || !file.open("DATA.CSV", O_CREAT | O_WRITE | O_TRUNC)) {
    Serial.println(F("SD problem"));
    sd.errorHalt();
  uint32_t t = micros();
  for (uint16_t r = 0; r < NREC; r++) {
    for (int i = 0; i < NADC; i++) {
      file.print(analogRead(i));
      file.print(',');
    // Fake overrun field.
    file.println(0);
  t = micros() - t;
  file.close();
  Serial.print("NADC: ");
  Serial.println(NADC);
  Serial.print("Average interval: ");
  Serial.print(t/NREC);
  Serial.println(" usec");
void loop() {}
Here is the output for two ADC channels.
Quote
NADC: 2
Average interval: 1219 usec
It ignores overruns but can't log two ADC channels at 1024 usec per record.  Of course the rate is dependent on the ADC values and I tied channel zero to 5V.
With nilSdLogger and four channels at 1000 usec:
Quote
type any character to end
Done!
Max Write Latency: 60940 usec
Unused Stack: 53 108
FIFO record count: 118
Minimum free count: 56
« Last Edit: February 01, 2013, 03:53:00 pm by fat16lib » Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
pito,
I can log the six Uno analog pins at 1000 Hz.  I wrote a printHexField() function that runs much faster than the decimal version.
You can't go faster than this because of the ADC conversion time.  Also the amount of buffering on Uno is marginal for six ADCs.
I may try a faster ADC clock on a Mega.
Here is the finish message:
Quote
Done!
Max Write Latency: 47748 usec
Unused Stack: 53 110
FIFO record count: 79
Minimum free count: 30
Here is the Hex data file:
Quote
PERIOD_USEC,1000
ADC0,ADC1,ADC2,ADC3,ADC4,ADC5,Overruns
3FF,2DA,238,208,3FF,3FF,0
3FF,30E,2AC,267,3FF,3FF,0
3FF,31B,2E6,2AB,3FF,3FF,0
3FF,32F,30D,2DE,3FF,3FF,0
3FF,369,342,314,3FF,3FF,0
3FF,3A6,37C,34B,3FE,3FF,0
3FF,3D6,3B1,381,3FF,3FF,0
3FF,3FF,3F0,3BB,3FF,3FF,0
3FF,3FF,3FF,3E0,3FF,3FF,0
3FF,3FF,3FF,3F3,3FF,3FF,0
3FF,3FF,3FF,3FC,3FF,3FF,0
3FF,3FF,3FF,3FF,3FF,3FF,0
Pin zero is tied to 5V, pins 1,2,3 are floating and pins 4,5 are connected to a DS1307 with pull ups.
Logged
Rapa Nui
Offline Offline
God Member
View Profile
You may use a simple data compression - do record changes per channel only, when no change "0" will be written..  smiley smiley
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I don't think compression would help.  The problem is CPU for formatting, not data size, so simple is better.
The printHexField() is six times faster than Arduino Print.  1.51 seconds vs 9.63 seconds for the same data.  The Hex file is a little smaller but that is not a big factor.
Quote
Test of println(uint16_t)
Time 9.63 sec
File size 128.89 KB
Write 13.38 KB/sec
Maximum latency: 47552 usec, Minimum Latency: 176 usec, Avg Latency: 474 usec
Test of printHexField(uint16_t, char)
Time 1.51 sec
File size 115.63 KB
Write 76.63 KB/sec
Maximum latency: 24132 usec, Minimum Latency: 44 usec, Avg Latency: 68 usec
A real speedup would happen with a properly designed binary logger.  That would require a fast external ADC.
I have a really fast library for MCP300x and MCP320x ADCs.  Conversion happens in parallel with readout. It takes about 10 microseconds to read a 12 bit ADC value with my fast bit-bang driver.
Logged
Rapa Nui
Offline Offline
God Member
View Profile
Yes, hex is faster.. A little bit laborious when working with .csv afterwards. For example 2E6 in your above hex file example would be a pain to process in excel smiley
I am thinking how to proceed with I2C. I have got 10DOF IMU (I2C) and want to log data from accelerometer, gyro, magnetometer, barometer and few ADC channels, ie. in 10ms period. Getting timestamps synced by RTC (I2C) and writing files with max length of 65k lines. And not loosing single data record..  smiley-wink
Do we need an I2C driver for the NilRtos?
« Last Edit: February 02, 2013, 03:19:36 pm by pito » Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Hex is a pain.  I have logged in binary and converted the file to text with a second pass.
AnalogIsrLogger20121219.zip http://code.google.com/p/beta-lib/downloads/list works this way.  It can log 8-bit ADC samples on an Uno at up to 100 ksps.  you get about 7 effective bits.
I have a very fast small AVR I2C driver that I plan to include with Nil.  It is master only and much faster than Wire.  It doesn't use interrupts and would work well in a high priority thread.
Logged
Rapa Nui
Offline Offline
God Member
View Profile
Quote
To get data from one sensor may take ~1.2msecs (@100kHz)..
Would such blocking driver be working with nil properly?
PS: I've tried to log the BMP085 bar sensor with current wire lib. Reading the pressure:
Code:
p->barpress = (uint32_t)bmp.readPressure();
takes 34.5ms @16MHz (inclusive a lot of integer math in it). So log periods >37ms work w/o an overrun.
I think I maybe need a thread where I read all the i2c sensors in a loop, lp smoothing data and updating them, as fast as possible. And the measuring thread will just copy the actual i2c sensors' data into the Record_t.
« Last Edit: February 03, 2013, 12:52:26 pm by pito » Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I think an interrupt based driver would help at 100 kHz.
Writing an interrupt base I2C driver that sleeps may not be too hard.
Edit:
I started looking at a general framework for I/O drivers on Nil.  It needs to accommodate device sharing.
It's likely more than one thread will want to use I2C or ADC channels.
« Last Edit: February 04, 2013, 08:18:29 am by fat16lib » Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
