Topic: sainsmart 3.2" demo error (Read 2951 times) previous topic - next topic
freerpg
Code: [Select]
// ITDB02_Graph16_Demo (C)2010 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use the library with the
// ITDB02-3.2 module. This demo should also work with the
// ITDB02-2.4 module in 16bit mode, but this is untested.
// This demo is not made for the ITDB02-3.2WC module. Use
// ITDB02_Graph16_Demo_Widescreen instead.
// This program requires the ITDB02_Graph16 (16bit mode).
// It is assumed that the ITDB02 module is connected to a
// ITDB02 Shield, a ITDB02 Mega Shield or that you know how
// to change the pin numbers in the setup.
#include <ITDB02_Graph16.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next line for the ITDB02 Shield
//ITDB02 myGLCD(19,18,17,16);
// Uncomment the next line for the ITDB02 Mega Shield
ITDB02 myGLCD(38,39,40,41);
  randomSeed(analogRead(0));
// Setup the LCD
  myGLCD.InitLCD(LANDSCAPE);
  myGLCD.setFont(SmallFont);
  int buf[318];
  int x, x2;
  int y, y2;
  int r;
// Clear the screen and draw the frame
  myGLCD.clrScr();
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 319, 13);
  myGLCD.setColor(64, 64, 64);
  myGLCD.fillRect(0, 226, 319, 239);
  myGLCD.setColor(255, 255, 255);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.print("*** ElecFreaks - 240x320 Color Display ***", CENTER, 1);
  myGLCD.setColor(255, 128, 128);
  myGLCD.setBackColor(64, 64, 64);
  myGLCD.print("H.Karlsen", LEFT, 227);
  myGLCD.print("(C)2010", RIGHT, 227);
  myGLCD.setColor(255,255,0);
  myGLCD.print("elecfreaks.taobao.com", CENTER, 227);
  myGLCD.setColor(0, 0, 255);
  myGLCD.drawRect(0, 14, 319, 225);
// Draw crosshairs
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.drawLine(159, 15, 159, 224);
  myGLCD.drawLine(1, 119, 318, 119);
  for (int i=9; i<310; i+=10)
    myGLCD.drawLine(i, 117, i, 121);
  for (int i=19; i<220; i+=10)
    myGLCD.drawLine(157, i, 161, i);
// Draw sin-, cos- and tan-lines
  myGLCD.setColor(0,255,255);
  myGLCD.print("Sin", 5, 15);
  for (int i=1; i<318; i++)
    myGLCD.drawPixel(i,119+(sin(((i*1.13)*3.14)/180)*95));
  myGLCD.setColor(255,0,0);
  myGLCD.print("Cos", 5, 27);
    myGLCD.drawPixel(i,119+(cos(((i*1.13)*3.14)/180)*95));
  myGLCD.print("Tan", 5, 39);
    myGLCD.drawPixel(i,119+(tan(((i*1.13)*3.14)/180)));
  delay(2000);
  myGLCD.setColor(0,0,0);
  myGLCD.fillRect(1,15,318,224);
// Draw a moving sinewave
  x=1;
  for (int i=1; i<(318*20); i++)
    x++;
    if (x==319)
      x=1;
    if (i>319)
      if ((x==159)||(buf[x-1]==119))
        myGLCD.setColor(0,0,255);
      myGLCD.drawPixel(x,buf[x-1]);
    y=119+(sin(((i*1.1)*3.14)/180)*(90-(i / 100)));
    myGLCD.drawPixel(x,y);
    buf[x-1]=y;
  delay(2000);
// Draw some filled rectangles
  for (int i=1; i<6; i++)
    switch (i)
      case 1:
        myGLCD.setColor(255,0,255);
      case 2:
      case 3:
        myGLCD.setColor(0,255,0);
      case 4:
      case 5:
    myGLCD.fillRect(70+(i*20), 30+(i*20), 130+(i*20), 90+(i*20));
  delay(2000);
// Draw some filled, rounded rectangles
    switch (i)
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
    myGLCD.fillRoundRect(190-(i*20), 30+(i*20), 250-(i*20), 90+(i*20));
  delay(2000);
// Draw some filled circles
    switch (i)
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
    myGLCD.fillCircle(100+(i*20),60+(i*20), 30);
  delay(2000);
// Draw some lines in a pattern
  myGLCD.setColor (255,0,0);
  for (int i=15; i<224; i+=5)
    myGLCD.drawLine(1, i, (i*1.44)-10, 224);
  for (int i=224; i>15; i-=5)
    myGLCD.drawLine(318, i, (i*1.44)-11, 15);
  myGLCD.setColor (0,255,255);
    myGLCD.drawLine(1, i, 331-(i*1.44), 15);
    myGLCD.drawLine(318, i, 330-(i*1.44), 224);
  delay(2000);
  myGLCD.fillRect(1,15,318,225);
// Draw some random circles
  for (int i=0; i<100; i++)
    myGLCD.setColor(random(255), random(255), random(255));
    x=32+random(256);
    y=45+random(146);
    r=random(30);
    myGLCD.drawCircle(x, y, r);
  delay(2000);
// Draw some random rectangles
    x=2+random(316);
    y=16+random(207);
    x2=2+random(316);
    y2=16+random(207);
    myGLCD.drawRect(x, y, x2, y2);
  delay(2000);
// Draw some random rounded rectangles
    x=2+random(316);
    y=16+random(207);
    x2=2+random(316);
    y2=16+random(207);
    myGLCD.drawRoundRect(x, y, x2, y2);
  delay(2000);
    x=2+random(316);
    y=16+random(209);
    x2=2+random(316);
    y2=16+random(209);
    myGLCD.drawLine(x, y, x2, y2);
  delay(2000);
  for (int i=0; i<10000; i++)
    myGLCD.drawPixel(2+random(316), 16+random(209));
  delay(2000);
  myGLCD.fillScr(0, 0, 255);
  myGLCD.fillRoundRect(80, 70, 239, 169);
  myGLCD.print("That's it!", CENTER, 93);
  myGLCD.print("Restarting in a", CENTER, 119);
  myGLCD.print("few seconds...", CENTER, 132);
  myGLCD.setColor(0, 255, 0);
  myGLCD.setBackColor(0, 0, 255);
  myGLCD.print("Runtime: (msecs)", CENTER, 210);
  myGLCD.printNumI(millis(), CENTER, 225);
  delay (10000);
ITDB02_Graph16_Demo_Landscape:27: error: no matching function for call to 'ITDB02::ITDB02(int, int, int, int)'
D:\arduino and shit\arduino-1.0.3\libraries\ITDB02_Graph16/ITDB02_Graph16.h:74: note: candidates are: ITDB02::ITDB02(int, int, int, int, int, byte)
D:\arduino and shit\arduino-1.0.3\libraries\ITDB02_Graph16/ITDB02_Graph16.h:73: note:                 ITDB02::ITDB02()
D:\arduino and shit\arduino-1.0.3\libraries\ITDB02_Graph16/ITDB02_Graph16.h:71: note:                 ITDB02::ITDB02(const ITDB02&)
ITDB02_Graph16_Demo_Landscape:28: error: 'ITDB02_Touch' does not name a type
I use the shield that bridges the 3.2 inch sainsmart to the mega and I just can't figure out what I am doing wrong here. the only other sketch provided has other issues.... all I want to do is figure out if the screen works cos I can't get it to work yet.
PaulS
The compiler is telling you exactly what the problem is. You are calling the constructor with 4 arguments, and it takes 5 or none or 1. It's quite likely that you do not want the one argument version, and it's fairly certain that you do not want the no argument version, either.
So, you need to figure out what the 5th argument is supposed to be, and add that.
If you need help, post a link to the library that you are using.
While you are at it, send a nasty letter to sain-not-so-smart telling them to get their shit together.
freerpg
well this library they gave has many flaws. I got a shield with it and the other example calls up analog pins... but the shield does not have any connections to the analog pins, its the oddest thing
http://www.sainsmart.com/arduino-compatibles/module/lcd-module/sainsmart-3-2-tft-lcd-display-touch-panel-pcb-adapter-sd-slot-for-arduino-2560.html
bottom of that page is where i got the downloads
PaulS
The second link on that page contains the library. The example in that library passes 5 arguments to the constructor.
Looks like the nasty letter needs to go to someone else.
Docedison
#4
Feb 02, 2013, 02:49 pm Last Edit: Feb 02, 2013, 02:52 pm by Docedison Reason: 1
Get the new libraries from Henning Karlsen, Search for UTFT. The stuff that you downloaded won't work properly at all. There is a new UTFT Ver 2.0 that will work perfectly. I have 5 of those displays and all work quite nicely... With the new libraries. The ITDB02 libraries are 3 or 4 years old... Junk. totally, Junk.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
freerpg
downloading the new libraries... the funky thing is the example in one library actually refers to analog pins but the shield does not use them.
PaulS
Quote
How can it not? How does it determine where you have pressed (where is not a digital value) without using analog pins?
freerpg
http://www.sainsmart.com/media/catalog/product/cache/1/image/500x500/b97a0c6c1d16e76f7464abfcbb6a0a8d/0/4/04_8.jpg
thats the pic from sainsmart themselves, thats the side with the analog pins. I assume it doesn't read an analog input instead a digital signal giving x and y co-ords
