Topic: Rookie - start over (Read 892 times) previous topic - next topic
cargol
Sorry,
I try  to explain again.
I'm trying to activate a relay from the output of  Arduino UNO
The relay is 12 Volts and  I have other of 9 volts. The transistror I use is a 2N222A and  I do not know that put in emitter resistor
I've tried everything and no way to activate the relay coil . If  is activated, then there is no way to disable
The program with leds  works correctly.
Someone has the outline of a circuit to do this.
thank you very much
Miquel
AWOL
Quote
what does that mean, please?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
cargol
What is the base-emitter resistor should I wear?
thank you
Papa G
thank you
How much current does the relay you intend to use need?
0AlphaOmega
For whom does the clock pulse? It pulses for you!
cargol
Perfect, Tested and working.
You've been very helpful.
Greetings from Catalonia
Miquel
