Author Topic: Rookie - start over  (Read 179 times)
Sorry,
I try  to explain again.
I'm trying to activate a relay from the output of  Arduino UNO
The relay is 12 Volts and  I have other of 9 volts. The transistror I use is a 2N222A and  I do not know that put in emitter resistor
I've tried everything and no way to activate the relay coil . If  is activated, then there is no way to disable
The program with leds  works correctly.
Someone has the outline of a circuit to do this.
thank you very much
Miquel
UK
what does that mean, please?
What is the base-emitter resistor should I wear?
thank you
Dallas, TX
thank you
How much current does the relay you intend to use need?
Does this article help?
here
For whom does the clock pulse? It pulses for you!
Perfect, Tested and working.
You've been very helpful.
Greetings from Catalonia
Miquel
