Topic: Need help with reading keyboard into an array (Read 2311 times) previous topic - next topic
doulos24
that didnt work either  :0
here is the example code stripped Ill re add my code wen this works!
/*  PS2Keyboard library example
 PS2Keyboard now requries both pins specified for begin()
 keyboard.begin(data_pin, irq_pin);
 Valid irq pins:
    Arduino:      2, 3
    Arduino Mega: 2, 3, 18, 19, 20, 21
    Teensy 1.0:   0, 1, 2, 3, 4, 6, 7, 16
    Teensy 2.0:   5, 6, 7, 8
    Teensy++ 1.0: 0, 1, 2, 3, 18, 19, 36, 37
    Teensy++ 2.0: 0, 1, 2, 3, 18, 19, 36, 37
    Sanguino:     2, 10, 11
 for more information you can read the original wiki in arduino.cc
 at http://www.arduino.cc/playground/Main/PS2Keyboard
 or http://www.pjrc.com/teensy/td_libs_PS2Keyboard.html
 Like the Original library and example this is under LGPL license.
 Modified by Cuninganreset@gmail.com on 2010-03-22
 Modified by Paul Stoffregen <paul@pjrc.com> June 2010
#include <PS2Keyboard.h>
const int DataPin = 3;
const int IRQpin =  2;
PS2Keyboard keyboard;
 keyboard.begin(DataPin, IRQpin);
 if (keyboard.available()) {
   // read the next key
   char c = keyboard.read();
   // check for some of the special keys
   if (c == PS2_ENTER) {
     Serial.println();
   } else if (c == PS2_DELETE) {
     Serial.print("[Del]");
     // otherwise, just print all normal characters
     Serial.print(c);
PaulS
It did so. It just didn't do what you wanted.
So, what did you want it to do, and what did it do?
HazardsMind
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
doulos24
it Works I had to change some stuff but it works You guys rock thanks!
HazardsMind
Great! What did you change? Could you post your working code, with comments so others can see too?
My GitHub:
doulos24
#20
Feb 04, 2013, 05:10 pm Last Edit: Feb 04, 2013, 10:16 pm by doulos24 Reason: 1
here is the working code. Only thing I'd like to be able to also read  PS2_DELETE
but I couldn't get that working but this works for now.
// arduino serial terminal
#include "Wire.h"
#include "LiquidCrystal.h"
LiquidCrystal lcd(0); // set lcd i2c adress
int reset_pin = 13;  // reset pin on the arduino mega
const int DataPin = 3; // data pin for ps/2
const int IRQpin =  2; // clock pn for ps/2
char line[16]; // store char array
int count = 0; // counter
unsigned long time = 60000; // 1 minuite delay
 pinMode(reset_pin, OUTPUT); // set pin 13 to output
 digitalWrite(reset_pin, HIGH);  // set pin High
 delay(1000); // delay 1 second
 keyboard.begin(DataPin, IRQpin); // start keyboard
 Serial.begin(9600); // start serial
 lcd.begin(16, 2);  // begin lcd
 lcd.setBacklight(HIGH); // turn backlight on
 lcd.setCursor(0, 0); // set cursor
 lcd.print(":"); // print a prompt
 if (keyboard.available() ){
   char kb = keyboard.read();  // read the ps2 keyboard input
   if(kb != PS2_ENTER){ // if input does not equal enter
     lcd.print(kb); // print char to lcd
     delay(20); // delay 20 ms
     line[count++] = kb; // add chars
     delay(50);  // delay 50 ms
   else{
     line[count++] ='\0';  // line = line + count = terminate
     Serial.print(line);  // print the added chars
     delay(1000);  // dealy 1 second
     count = 0;  // reset count
     lcd.clear();  // clear lcd
     delay(50);  // delay 50ms
     lcd.print ("sending"); // print sending to lcd
     delay(5000); // delay 5 seconds
     lcd.print(":"); // print prompt
     delay(time); // delay 1 minuite
     lcd.print("reset");  // print reset to lcd
      digitalWrite(reset_pin , LOW); // send a reset to the arduino mega
     delay(2000); // delay 2 seconds
     digitalWrite(reset_pin , HIGH);  // finish reset
doulos24
#21
Feb 04, 2013, 05:25 pm Last Edit: Feb 04, 2013, 05:28 pm by doulos24 Reason: 1
And here is the code to go with it
/* max 24 relay controller and pump pulser simulator
this program takes a serial string like this "12.900.14.14"  and parses it up into variables
for relay count 1-12, number of pulses, pulse width, and delay beween pulses.
Then it prints that to the serial port like this "Relays 12 Pulses 900 Length 14ms Delay 14ms"
created 1/7/13
last edit 2/1/13
by Will Meyers
unsigned long counter =0; // set counter to 0
int pulse =52; // pin thats connected to the pulse simulator
int led = 13; // status led
int dly= 150; // delay between relay functions
int relay[]={
 14, 15, 16, 17, 18, 19, 20, 21, 30, 31,\
32, 33, 34, 35, 36, 36, 38, 39, 40, 41, 42, 43, 44, 45}; // relay array with all 24 pins
int pinCount = 24;  // the number  index for the array
void setup() // setup arduino functions
 pinMode (pulse, OUTPUT);  // set pin 52 to an output
 pinMode (led, OUTPUT); // set pin 13 to an output
 Serial.begin(9600);    // start serial connection
 Serial.println("reset");
 for(int n=0; n<pinCount;n++){  // for loop
   pinMode(relay[n],OUTPUT);  // set all relay pins as output
   digitalWrite(relay[n], HIGH); // write all relay pins high SETS THEM TO OFF
void loop()  // run main loop
 if (Serial.available() > 0)  // wait for data
   int w = Serial.parseInt();   // this is the relay selection variable from 1 -12
   unsigned long x = Serial.parseInt();  // this is for the pulse counter
   int y = Serial.parseInt(); // this sets how long you want to hold the pulse high
   int z = Serial.parseInt(); // delay between pulses
   delay(1); // neccesary delay to use Serial.parseint() ;
   Serial.print("relays "); // print "relays " to serial port
   Serial.print (w * 2);   // print the w x 2 or relay pins to the serial port
   Serial.print(" Pulses "); // print "pulses "to the serial port
   Serial.print(x); // print the var value of x to the serial port
   Serial.print(" Length "); // print "length " to the serial port
   Serial.print(y);
   Serial.print( "ms"); // print the value of y then "ms"  to the serial port
   Serial.print(" delay " );  // print "delay"  to the serial port
   Serial.print(z); // print the value of z  to the serial port
   Serial.println("ms");  //print "ms" to the serial port
   for(int n=0; n < (w * 2); n++){  // for loop relay counter * 2
     digitalWrite(relay[n], LOW); // set all selected pins low  or ON
     delay(dly); // delay for variable
   delay(dly * w );  // max delay needed  to turn on all pumps the var dly * relay selection 1-12
   while(counter<(x)) // while counter is less the x do this loop
     PORTB = 0b10000010; // port adress of the pulse pin 52 pull it HIGH
     delay(y) ;       // delay by y  or how long to hold the pin high
     PORTB = 0b00000000; // pull everything on this port LOW
     delay(z);   // delay by z delay between pulses
     counter++; // increment counter by 1
     while(counter==(x)) // after counter equals x do this loop
       delay(10); // delay by the value of 10ms
       PORTB = 0b00000000; // set all pins in this port LOW
       delay(1000); // delay by the value of 1 second
         digitalWrite(relay[n], HIGH);// write n # of relay pins HIGH or OFF
         delay(dly); // delay by variable dly
       Serial.println("done");  // print "done" to the serial port on a new line
       return; // fin
doulos24
thanks guys for helping me make this possible my work is very pleased
http://www.youtube.com/watch?v=TyJvdAa4VKQ&feature=youtu.be
