Loading...
Pages: [1]   Go Down
Author Topic: Custom Characters example question  (Read 204 times)
Bryan, Ohio
Offline Offline
Newbie
View Profile
I tried to compile the custom characters example that comes with the arduino program.  I get the error call of overloaded \write('int') is ambiguous. If i change the 0 to a 1 in this line   lcd.write(0); it compiles.
I tried the code from this post
Code:
#include  <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// ^2
byte newChar1[8] = {
  B01100,
  B10010,
  B00100,
  B01000,
  B11110,
  B00000,
  B00000,
  B00000
// (C)
byte newChar2[8] = {
  B11111,
  B10001,
  B10101,
  B10111,
  B10101,
  B10001,
  B11111,
  B00000
// (R)
byte newChar3[8] = {
  B11111,
  B10001,
  B10101,
  B10001,
  B10011,
  B10101,
  B11111,
  B00000
// TM
byte newChar4[8] = {
  B01110,
  B00100,
  B00100,
  B00000,
  B01010,
  B10101,
  B10101,
  B00000
int i = 0;
  lcd.createChar(0, newChar1);
  lcd.createChar(1, newChar2);
  lcd.createChar(2, newChar3);
  lcd.createChar(3, newChar4);
  lcd.begin(16, 2);
  for(int n = 0; n < 4; n++)
    lcd.setCursor(n,0);
    lcd.write(n);
http://arduino.cc/forum/index.php/topic,135955.0.html
and it compiles, whats the difference
code from example
Code:
  LiquidCrystal Library - Custom Characters
 Demonstrates how to add custom characters on an LCD  display.
 The LiquidCrystal library works with all LCD displays that are
 compatible with the  Hitachi HD44780 driver. There are many of
 them out there, and you can usually tell them by the 16-pin interface.
 This sketch prints "I <heart> Arduino!" and a little dancing man
 to the LCD.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K potentiometer:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 * 10K poterntiometer on pin A0
 created21 Mar 2011
 by Tom Igoe
 Based on Adafruit's example at
 https://github.com/adafruit/SPI_VFD/blob/master/examples/createChar/createChar.pde
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
 Also useful:
 http://icontexto.com/charactercreator/
// include the library code:
// initialize the library with the numbers of the interface pins
// make some custom characters:
byte heart[8] = {
  0b00000,
  0b01010,
  0b11111,
  0b11111,
  0b11111,
  0b01110,
  0b00100,
  0b00000
byte smiley[8] = {
  0b00000,
  0b00000,
  0b01010,
  0b00000,
  0b00000,
  0b10001,
  0b01110,
  0b00000
byte frownie[8] = {
  0b00000,
  0b00000,
  0b01010,
  0b00000,
  0b00000,
  0b00000,
  0b01110,
  0b10001
byte armsDown[8] = {
  0b00100,
  0b01010,
  0b00100,
  0b00100,
  0b01110,
  0b10101,
  0b00100,
  0b01010
byte armsUp[8] = {
  0b00100,
  0b01010,
  0b00100,
  0b10101,
  0b01110,
  0b00100,
  0b00100,
  0b01010
  // create a new character
  lcd.createChar(0, heart);
  lcd.createChar(1, smiley);
  lcd.createChar(2, frownie);
  lcd.createChar(3, armsDown);
  lcd.createChar(4, armsUp);
  // set up the lcd's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the lcd.
  lcd.print("I ");
  lcd.write(0);           //******  This is where the error shows up ******
  lcd.print(" Arduino! ");
  lcd.write(1);
  // read the potentiometer on A0:
  int sensorReading = analogRead(A0);
  // map the result to 200 - 1000:
  int delayTime = map(sensorReading, 0, 1023, 200, 1000);
  // set the cursor to the bottom row, 5th position:
  lcd.setCursor(4, 1);
  // draw the little man, arms down:
  lcd.write(3);
  delay(delayTime);
  // draw him arms up:
  lcd.write(4);
  delay(delayTime);
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Quote
We ran into what I think was a similar problem a few weeks ago and it has something with how the compiler deals with a '0' (which is the address needed to access the first custom character).
Try substituting a '8' instead of '0' when you are dealing with displaying the first custom character.  Sorry, I'm illiterate in 'C' so I can't tell you exactly how to do that.
I'll see if I can find that previous forum topic.
[Edit] Well that didn't take long, here it is:  --> http://arduino.cc/forum/index.php/topic,140917.0.html
Don
« Last Edit: February 03, 2013, 05:41:05 pm by floresta » Logged
Bryan, Ohio
Offline Offline
Newbie
View Profile
Using eight does work.  I'm a little surprised that an example that came with the arduino program wouldn't compile.  and it works in the other code.
thank's for the info.
Logged
Bryan, Ohio
Offline Offline
Newbie
View Profile
I also tried
int n=0;
lcd.write(n);
that works
lcd.write(0);
doesn't work
Logged
Offline Offline
Newbie
View Profile
  lcd.write((uint8_t)0);  // add uint8_t when calling zero
Logged
That little black caterpillar you just stepped on will set you back a few bucks....
Pages: [1]   Go Up
Print
Jump to:
