Loading...
Pages: [1]   Go Down
Author Topic: Initiallizing local variables  (Read 158 times)
Malaysia
Offline Offline
Sr. Member
View Profile
guys i was wondering about local variable
my question is something like this
I always and i mean almost always initialize my variable to be a global variable, but i was wondering could i initiate it in someway so it to become a local variable
heres an example:
Code:
int Count=0;
{ yada yada yada}
 did something heres that causes
  Count++;
but could somehow i want it to be like this
Code:
  int Count=0;
somthing happen somwhere here
and then Count++;
i know that if i do it as the second way that is initializing the Count in the loop section will make the Count value reset to 0 every time it loop
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Resetting the value may or may not be what you want; it isn't clear to me from your post.
Does the "static" keyword answer any of your questions?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Malaysia
Offline Offline
Sr. Member
View Profile
Sorry AWOL if i'm not clear with my question, I want to know if i could initialize Count variable as a local variable inside the void loop()?
i what the value to be the last value that it has b4 the loop function loop around, i dont want it to be reset back to 0.
Logged
New Jersey
Offline Offline
Edison Member
View Profile
The static modifier does what you want:
Code:
 static int Count=0;
and then Count++;
Logged
Malaysia
Offline Offline
Sr. Member
View Profile
now i know what static does, so this way i do not need to declare to may global variable now huh.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
TIP: Google about the scope rules of variables in C.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
No you don't. There are lots of different static so keep an open mind for next time it may mean something else.
If you want a variable only that function needs to access, you can use static. Non static local variables are released after function call so memory is free for other things. Static variables are kept so don't define too many of them.
Logged
Pages: [1]   Go Up
Print
Jump to:
