Author Topic: Having trouble tying multiple functions together  (Read 320 times)
W9LZ
I've built a kluge that performs 5 functions. I can make any of the five work perfectly as standalone sketches. I'm trying to use the Serial Monitor to input a selection that through the use of a switch. The switch/case combo works except it only allows one iteration of the called function. If I send say "1111111" it will run 7  times, "2222" 4 times, etc. Anyone have an idea on a slick method to pull this off?
« Last Edit: February 03, 2013, 05:55:09 pm by Learning » Logged
East Anglia (UK)
May all of your blinks be without delay
Show us the code !
W9LZ
Here's the basic structure. Thanks for looking at it.
static char mode;
#include <NewPing.h>
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
int FLASH_PIN = 13;
int MIC_PIN = 0;
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  pinMode(MIC_PIN, INPUT);
  pinMode(FLASH_PIN, OUTPUT);
  if(Serial.available())
    char mode = Serial.read();
    Serial.println(mode);
    switch(mode)
      case '1':
      Sound();
      break;
      case '2':
      Ultrasonic();
      break;
      case '3':
      Proximity();
      break;
      case '4':
      Magnetic();
      break;
      case '5':
      Mystery();
      break;
void Sound()
   Serial.print("Sound");
  // while(mode == '1')
  //  if(Serial.available())
  int value = analogRead(MIC_PIN);
  Serial.println(value);
    if (value < 120)
    Serial.print ("SDFGHJKLJHGFDGHJKL:JHGFSDGHKJHGFSDSGHJKHGFSD");
    digitalWrite(FLASH_PIN,LOW);
  digitalWrite(FLASH_PIN,HIGH);
void Ultrasonic()
// while(mode == '2')
   Serial.print("Ultrasonic");
   delay(50);         // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
   unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
   Serial.print("Ping: ");
   Serial.print(uS / US_ROUNDTRIP_CM / 2.54); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
   Serial.println("in");
   if (uS / US_ROUNDTRIP_CM /2.54 < 3)  // 12 inch out
       digitalWrite(FLASH_PIN,LOW);   // flash it!
       digitalWrite(FLASH_PIN,HIGH);  // don't flash it!
void Proximity()
  // while(mode == '3')
  // RF disrupter sketch here
  Serial.print("Proximity");
  Serial.print(mode);
void Magnetic()
 //  while(mode == '4')
  // Hall effect sketch
  Serial.print("Magnetic");
  Serial.print(mode);
void Mystery()
  //while(mode == '5')
    // Jack Bauer special
  Serial.print("Mystery");
  Serial.print(mode);
« Last Edit: February 03, 2013, 09:18:54 pm by Nick Gammon » Logged
North Queensland, Australia
You say it only allows one iteration, then its running 7 and 4 times.
Is your intention to only respond to one of the '1' in "1111111"?
If so, flushing the RX buffer may help after reading the value:
while( Serial.available() ) Serial.read();
Melbourne, Australia
Shannon Member
Lua rocks!
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
W9LZ
No, the intention is to dynamically switch between functions by doing a single key entry through the serial monitor. It will 'run' the function each time it receives a number like 11111, but I want it to continue running that function until I enter another choice.
Maybe something like this:
void loop(){
  static char mode = '1'; //Default starting mode.
  //Get new mode if available
  if(Serial.available()){
  //Now your switch
  Serial.println( mode );
  switch( mode ){
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
What about reading it from serial and then store it in a temporary variable. Now with that variable you can check if any new incoming chars are different or not. If it is different, do another function, if not, do same function.
Use a while loop to compare the variables.
« Last Edit: February 03, 2013, 09:19:40 pm by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
W9LZ
Still only runs once and stops. I was pretty sure I tried this about 3 days ago, haha. Driving me nuts.
Well how are you sending the data, if you send a string with a null terminator you need to account for it.
You could flush all remaining characters.
Or maybe even better, check if the character is what you are looking for:
    char temp = Serial.read();
    if( ( temp >= '1' ) && ( temp <= '5' ) ){
      mode = temp;
W9LZ
Yep, this was the bug! The old null character being ignored trick.  Thank you!!!
-Jim
Shannon Member
Lua rocks!
You have multiple declarations of mode. That is bad practice:
static char mode;
These are all different variables. The resulting behaviour may not be what you expect.
W9LZ
Thanks for the "positive" response.
