Loading...
Pages: [1]   Go Down
Author Topic: Connecting WiFly Shield  (Read 114 times)
Offline Offline
Newbie
View Profile
Hello,
I am trying to have WiFly shield connect to my wireless router.
I have Arduino Duemilanove and WiFly shield RN-131 stacked together. I was trying to run "WiFly_Autoconnect_Terminal" from the example in WiFly_Shield library. I have edited the Credentials.h to match my network but I get no responses not even "Association failed" message. I am sure the code is not the problem, am I missing or forgetting to do something?
Any advice would be appreciated, thank you.
Code:
#include <SPI.h>
#include <WiFly.h>
#include "Credentials.h"
  Serial.println("\n\r\n\rWiFly Shield Terminal Routine");
  WiFly.begin();
  if (!WiFly.join(ssid, passphrase)) {
    Serial.println("Association failed.");
    while (1) {
      // Hang on failure.
  Serial.println(WiFly.ip());
  Serial.println("Associated!");
  // Terminal routine
  // Always display a response uninterrupted by typing
  // but note that this makes the terminal unresponsive
  // while a response is being received.
  while(SpiSerial.available() > 0) {
    Serial.write(SpiSerial.read());
  if(Serial.available()) { // Outgoing data
    SpiSerial.write(Serial.read());
Code:
#ifndef __CREDENTIALS_H__
#define __CREDENTIALS_H__
// Wifi parameters
char passphrase[] = "12345678";
char ssid[] = "Testing";
#endif
Logged
Pages: [1]   Go Up
Print
Jump to:
