Author Topic: I2C LCD Display Problem (Only 16xSquares)  (Read 576 times)
Hello,
I just bougth a 16x2 Display with sainsmart I2C adapter on the backside.
The original Library cant be used for this so i downloaded this one:
https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
It is correctly shown in the Library Tab in the Arduino software.
I use a Arduino nano, where the I2C Pins are A4 and A5.
My connections are:
Vcc to 5V Arduino
Gnd to Gnc Arduino
SDA to A4
SDL to A5
If i turn the Arduino on, the displays backlight turn on and the first row of the display shows
16 Squares.
If i just try the Example in the Package (Tested other Packages already) it doesnt work.
I upload the sketch and nothing happens.... smiley-sad
The display only shows the 16 squares.
What im doing wrong?
How i get Text to this Display!?
im getting crazy
I hope someone can help me with this.
Examplecode:
#include <Wire.h>
#define BACKLIGHT_PIN     13
LiquidCrystal_I2C lcd(0x38);  // Set the LCD I2C address
//LiquidCrystal_I2C lcd(0x38, BACKLIGHT_PIN, POSITIVE);  // Set the LCD I2C address
// Creat a set of new characters
const uint8_t charBitmap[][8] = {
   { 0xc, 0x12, 0x12, 0xc, 0, 0, 0, 0 },
   { 0x6, 0x9, 0x9, 0x6, 0, 0, 0, 0 },
   { 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0, 0x0 },
   { 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0, 0x0 },
   { 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0x0 },
   { 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0x0 },
   { 0x0, 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0x0 },
   { 0x0, 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0x0 }
   int charBitmapSize = (sizeof(charBitmap ) / sizeof (charBitmap[0]));
  // Switch on the backlight
  pinMode ( BACKLIGHT_PIN, OUTPUT );
  digitalWrite ( BACKLIGHT_PIN, HIGH );
  lcd.begin(16,2);               // initialize the lcd
   for ( int i = 0; i < charBitmapSize; i++ )
      lcd.createChar ( i, (uint8_t *)charBitmap[i] );
  lcd.home ();                   // go home
  lcd.print("Hello, ARDUINO ");
  lcd.setCursor ( 0, 1 );        // go to the next line
  lcd.print (" FORUM - fm   ");
  delay ( 1000 );
   lcd.home ();
   // Do a little animation by writing to the same location
   for ( int i = 0; i < 2; i++ )
      for ( int j = 0; j < 16; j++ )
         lcd.print (char(random(7)));
   delay (200);
« Last Edit: February 03, 2013, 06:25:28 pm by cthulhu666 » Logged
Manchester (England England)
Online Online
Solder is electric glue
The second line of the display might be a lot further on in the LCD's memory map. Try printing a series of squares and see where the second row appears. It might be 20, 32, 40 or even 60, 64 spaces away from 0,0
i cant print anything.
only the backlight ist on... and the 16 squares
no matter what i upload nothing happens.
only 16 squares are shown.
and i dont want to show them...
i only want the hello world text there!
Online Online
I am assuming that
Shows nothing.
Yes you can.
  lcd.print("Hello, ARDUINO**1234567890abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ!@£$%^&*() ");
Now see what appears on the second line.
i changed it like u told me and nothing happened.
this is what i had and what i have now too:
usually the example should work!?
i think im doing something wrong!?
why?
i just deleted the one with forum -fm
and replaced the other one with the code u wrote!?
what else u said to me?
sorry if i forgot something
im just getting crazy smiley-sad
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Do you know if your library have a function call "lcd.init();"?
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
yes this function is available
but is not written in the example
Queens, New York
Try it anyways, it goes it setup(). Is the lcd 16x2? Try changing the address to 0x20 or 0x27.
« Last Edit: February 03, 2013, 07:25:40 pm by HazardsMind » Logged
omfg...
my adress was wrong.
its not 0x20 or sth like in the example.
its 0x3F
now the display does something but not very much...
it only turns backlight on and instant off
nothing more happens
Central MN, USA
Are you sure the library is designed for that display? If not, stop. Get the original library that didn't work and make it work. You are wasting your time if you have the wrong library.
i realy dont know, if it is the right library
i bougth this one:
http://www.ebay.de/itm/221038737474?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_3016wt_1139
The seller send an image to me where is a example code in it.
at the top of the code this is written:
//YWROBOT
So i downloaded a library for YWROBOT.
Changed the adress to 0x3F in the example code and
uploaded it.
with the code i can turn on the lcd backlight
but i cant write with this code!?
What u mean with " get the original library"?
the original arduino lib?
Central MN, USA
By original I meant the library coming from the manufacturer. Apprently that was not possible. The only link on the ebay page was broken. There are many I2C lcd backpacks and most of them differ in some details at the hardware level so using one display purchased from store A and library downloaded from store B is not going to help you. It also sounds wrong for the seller to profit from hardware and have another store support software. Please ask the seller to email you the library, which is a very small attachment. If they won't email you, you know you should stay away from them and their brand.
BTW, I don't know if sainsmart and ywrobot are related businesses so the seller could be scamming both businesses and you smiley
UK
As humankind continues to socially devolve, the an isn't art of using the search function is lost in the mists of time......
http://arduino.cc/forum/index.php?topic=106655.0
