Loading...
Pages: 1 [2]   Go Down
Author Topic: Due I2C not working  (Read 2451 times)
West Yorkshre UK
Offline Offline
Newbie
faster, smaller, more beautiful
View Profile
Ive captured the SCL and SDA and I DO see the Ack and levels are good. But for some reason the Due is not seeing it . This is with the wire library. Ive since used the MPU6050 code with the I2Cdev library and it works. But I would like to get to the heart of the problem. Trying scan by using  error=I2Cdev::readbyte(addr++,0,buff);  in a loop still doesnt work find the Ack.
Logged
Offline Offline
Newbie
View Profile
I am also experiencing problems with I2C between two Dues. Nothing working at all so far, I even went back to the basic examples and nothing happened. Are the designers aware of this potential issue with either the pullups or the library (I hope it's the latter!!)? Please acknowledge.
Logged
USA
Offline Offline
Newbie
View Profile
WWW
The heart of the problem is that each time the wire library checks the TWI status register, the NACK bit is automatically cleared by hardware (34.11.6 TWI Status Register, page 748 in the SAM3X8E datasheet).  The wire library is broken in this regard.  If you need to detect NACK's, you will need to wait for updates, or spin your own interface.
However, it looks like you have trouble detecting ACK's.  I suspect that you probably have some other issue going on.  Try posting your code...
Do not connect two Due's together on a common I2C bus without a buffer of some sort.  The combination of both boards, and their pull-up resistors in parallel, will unnecessarily stress the DUE's TWI pins.  I recommend that the on-board pull-ups be removed from the DUE's pcb by default.  Use larger external pull-up resistors.
How big?  Check this out:
http://www.edn.com/design/analog/4371297/Design-calculations-for-robust-I2C-communications
-Chris
Logged
Offline Offline
Jr. Member
View Profile
Hi, I also have some trouble with the I2C: I am very new to this communication protocol, So I was trying to see how it works, and I tried making my Due and my Uno talk to each other. It worked, but when I send charters from the Due to the Uno, half is lost.
Here are my codes:
for the Uno (slave):
Code:
#include <Wire.h>
char buffer[64];
byte serialpos=0, wirepos=0;
   Wire.begin(0x02);
   Serial.println("I2C test Starting...");
   Wire.onRequest(handler);
   Wire.onReceive(receiver);
  if(Serial.available())
    buffer[serialpos]=Serial.read();
    serialpos++;if(serialpos>64)serialpos=0;
void handler()
  if(wirepos<serialpos)
  Wire.write(buffer[wirepos]);
  wirepos++;if(wirepos>64)wirepos=0;
void receiver(int num)
  while(Wire.available())
    char c=Wire.read();
    Serial.println(c);
and for the Due (master):
Code:
#include <Wire.h>
int old, now;
   Wire.begin();
   Serial.println("I2C test starting...");
   old=millis();now=millis();
    Wire.beginTransmission(0x02);
    Wire.write(Serial.read());
    Wire.endTransmission();
  now=millis();
  if(now-old>1001)
    old=now;
    Wire.requestFrom(0x02,1);
    delay(10);
      char c=Wire.read();
      if(c>31)Serial.println(c);
Any help will be appreciated. Thanks.
Logged
L.C.
Offline Offline
Newbie
View Profile
I'm not even getting a clock signal on SCL1, just running the example file "master reader"! SCL1 just sits low at 0V (referenced to a gnd pin) and SCL(21) does the opposite (3.3V). I was surprised by how easy it was to pull SCL1 high even with a 100k resistor, as though it is not trying to pull down the line at all, ever. Is my Due faulty? Is there some special way that SCL should be terminated that I missed which is causing this behaviour? I would really appreciate a developer looking into this as my current project was designed around lots of Dues talking I2C.... oh dear :-( The previous posts suggest that both the Wire library is in error AND that the hardware has been badly designed with too small pullup resistors and that Dues therefore cannot be connected on a single I2C bus. Please confirm. This is such a fundamental (and disappointing) issue!
Logged
Offline Offline
Jr. Member
View Profile
Actually, it's my code which was bad, I modified it and all worked fine for me smiley Sorry for disturbing.
Logged
L.C.
Germany
Offline Offline
Full Member
View Profile
It would be nice if you share your new code with us.
Logged
Offline Offline
Jr. Member
View Profile
yep sorry. here it goes: for the Due (master)
Code:
#include <Wire.h>
int old, now;
   Wire.begin();
    old=now;
    //delay(1);
      char c=Wire.read();
and for the Uno:
Code:
#include <Wire.h>
char buffer[256];
   Wire.begin(0x02);
void loop() {  // put your main code here, to run repeatedly:
void handler()
    char c=Serial.read();
    Wire.write(c);
    char c=Wire.read();
    Serial.println(c);
Hope this helps smiley
Logged
L.C.
Pages: 1 [2]   Go Up
Print
Jump to:
