Topic: ArduinoBT Windows 7 problem (Read 729 times) previous topic - next topic
marcopaolieri
I am trying to program and control an Arduino BT via a Windows 7 PC. I have problems both programming and communicating with the board using a serial terminal.
To program, I tried the trick of pressing the reset button before, but it does not work. Any suggestion? On my macmini I can program it, so I do not think nothing is wrong with the board.
Can you suggest me a program to communicate as serial terminal? I tried real term, but it does not work. Moreover it creates 2 serial port on my PC, one for incoming and one for outgoing communications. Which should I use? My sketch is simply an analog port reading and printing on the serial port.
Once the BT board is linked to the PC, if I press the reset button on the board, I do not loose the connection,isn't it?
thanks,
marco
PS: I think the best is to buy a normal arduino and then add a BT shield, because this BT board is making me crazy :(
mascaproj13
Looks like it is the similar problem I have but with vista. Crossing fingers hoping some one from Arduino would look into this issue and fix or suggest a patch or solution.
pito
#2
Feb 04, 2013, 02:06 am Last Edit: Feb 04, 2013, 02:10 am by pito Reason: 1
Programming works fine ie.:
http://blog.iteadstudio.com/warless-program-your-iteaduino-bt-2/
Communication - you may try TeraTerm. Choose the Outgoing com.
PS: maybe you have to start with communication troubleshooting - gather some experience with BT and then go towards programming via BT.. :)
