Loading...
Pages: 1 [2]   Go Down
Author Topic: Program stops after button press  (Read 368 times)
Malaysia
Offline Offline
Sr. Member
View Profile
try this
Code:
uint8_t Switch = 2;
uint8_t Led =13;
boolean LedState =LOW;
int SwitchState =0;
int SwitchDebounce;
int LastSwitchState=HIGH;
int LastSwitchDebounce=LOW;
unsigned long LastDebounceTime = 0;
unsigned long DebounceDelay = 50;
  pinMode(Switch,INPUT);
  digitalWrite(Switch,HIGH);
  pinMode(Led,OUTPUT);
  int CurrentSwitch = digitalRead(Switch);
  if (CurrentSwitch != LastSwitchDebounce)
    LastDebounceTime = millis();
  if ((millis() - LastDebounceTime) > DebounceDelay)
    if (CurrentSwitch != LastSwitchState)
      if (CurrentSwitch == LOW)
        CountNumber++;
    LastSwitchState=CurrentSwitch;
  if ( !CurrentSwitch && !LastSwitchState) CountNumber++;
  Serial.println(CountNumber);
  LastSwitchDebounce = CurrentSwitch;
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
@ash901226
No, he wants this.
Code:
const int buttonPin = 2;
int buttonState = 0;
int  lastReading = 0;
long onTime=0;
int count = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH && lastReading == LOW) { // single press
    onTime = millis();
    count++;
  //held
  if (buttonState == HIGH && lastReading == HIGH) { //single press + hold
    if ((millis() - onTime) > 500 ) { // looks to see if button is pressed for more than half a second.
      delay(200); // **the rate in which the numbers increase**
      count++;
      lastReading = LOW;
  Serial.println(count);
  lastReading = buttonState;
« Last Edit: February 05, 2013, 08:28:03 am by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Newbie
View Profile
The code presented doesn't work.
Right now, the code I have is perfect, because that works perfectly for everything (keeping it pressed etc).
The only problem now must be in the circuit. Because when I press 1 of the buttons or both, the LED flashes faaaaar more brightly.
 So I think that somewhere by pressing the button, the circuit gets closed and therefore more voltage flowsthrough the LED. I have no electronical knowledge, so there is my problem smiley-razz.
First I thought I didn't need a branch from the 5V for the LED or for the buttons, but I need it, or I have no parallel I think.
Logged
Offline Offline
Newbie
View Profile
I have found what the problem was in the end.
The problem was that the LED was turned on and off too fast after another.
What I mean by that is that by the time the LED was set FROM HIGH to LOW, it barely had gotten time to go HIGH, resulting in only a super small blink.
I have added a delay which does not affect my timer code.
The sleep could not be bigger or equal than 60000 (ms) / BPM.
The resulting code:
Code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int BPM = 120;
int minSwitchState;
int plusSwitchState;
float toDelay;
long previousMillis = 0;
boolean buttonPressed;
int counter = 0;
  lcd.begin(16, 2);
  updateDisplay();
  //red output LED
  pinMode(13, OUTPUT);
  //green output LED
  pinMode(10, OUTPUT);
  //input buttons
  pinMode(7, INPUT);
  pinMode(8, INPUT);
  buttonPressed = false;
  minSwitchState = digitalRead(8);
  plusSwitchState = digitalRead(7);
  if(minSwitchState == HIGH) {
    buttonPressed = true;
    BPM++;
    updateDisplay();
  if(plusSwitchState == HIGH) {
    if(BPM > 1) {
      BPM--;
      updateDisplay();
  if(currentMillis - previousMillis >= toDelay && !buttonPressed) {
    counter = counter % 4 + 1;
    if(counter == 1) {
      digitalWrite(10, HIGH);
    }else{
      digitalWrite(13, HIGH);
    delay(100);
    Serial.println(currentMillis / 1000.0);
  }else{
    digitalWrite(13, LOW);
    digitalWrite(10, LOW);
void updateDisplay() {
  toDelay = 60000.0 / (float) BPM;
  lcd.clear();
  lcd.print("Kies BPM: ");
  lcd.setCursor(0, 1);
  lcd.print(BPM);
  delay(100);
Thanks a lot all, this can be put to [SOLVED] smiley!
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
There was something wrong with my code?, I thought it did EXACTLY what you wanted. You press it once, it increments once, you press and hold it and it increments at the delay(200) rate.
Ok, well if you got it to work on your own, then thats even better. You found the problem and was able fixed it.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
