Topic: Controlling position of linear actuator (Read 8510 times) previous topic - next topic
ok, doing some math...
PWM frequency is 125Hz. Minimum duty cycle is 0%. The steps are in 12.5% for 8 steps = 100%
If I were to translate that to 0 to 255, I would have duty cycles of 32, 64, 98, etc... (256/8)
Assuming I keep the PWM frequency at 125Hz
32 would give me 1ms
64 would give me 2ms
and so forth...
Is my math correct?
hello retroplayer.
i am working on a similar project.
i have a linear actuator that uses a brushless dc motor, that has internal hall sensors to track count its steps.
i too get my position info by counting the hall sensor steps. i too have external limit switches to know when i reach the extreme positions.
i am wondering about your success to implement PID control to get better position control.
i am hoping to constantly give the arduino or teensy new position data over OSC or serial communication. and i am hoping for smooth motion from source to target positions, even if new position data is constantly send.
do you have any test code i could test on my setup?
