Topic: fixed point variables? (Read 2710 times) previous topic - next topic
hategps
Helo everybody, i'm trying to convert a simulink model from float to fixed point variables to see if i can improve or not its velocity on arduino. i should decide a suitable data type to run on target for Arduino mega2560. simulink suggestion is: fixdt(Signed, WordLength, FractionLength). however,it's not clear (to me) if that data type becomes an int type on arduino or not and how it is treated in that case.
i've tried a trivial model using that data type, it runs on arduino but doesn't seem to improve velocity..
what do you think about it?
Grumpy_Mike
A trivial example will not, but how about one where you do some arithmetic on the value.
Post the code if you want specific help.
hategps
the simple model was still in simulink and i did it just to know if arduino can handle fixdt data type. i wouldn't even know how to write that data type on the ide. is there any easier way to represent a fixed point variable?
michinyon
There is no "fixed point" type for Arduino, as far as I am aware.
What you can do,  is represent your problem using integers.    For example,  if your GPS problem originally
uses floating point numbers which represent metres,   you can change it to use integers which represent millimetres.
lloyddean
What is the range of values that your fixed type requires?
Are you most concerned with speed or accuracy?
PeterH
The type needs to be chosen so that the variables can hold the full range of values that they need to hold. So you need to work out what the range of possible values is, and then choose the appropriate integer type to hold those values.
For example if you need to hold a percentage (0 .. 100) to three decimal places then the range of possible values is 0 .. 100000; a long is the most appropriate integer type for that range.
devobitch
hi guys
i have a similar question
how do you limit the amount of digits to the right of the decimal point
temp_f = sht1x.readTemperatureF();
lcd.print("Temperature: ");
lcd.print(temp_f, DEC);
prints way to many digits i just want to print 2 digits to the right of decimal point
thanks
devobtch
AWOL
lcd.print(temp_f);
Default, two decimal places.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
hategps
i have variables with quite different ranges of value, but i did specify that on the model.
the model is not so slow when using double type, so i'm interested in good accuracy
clear. when i choose to my question is just if you know something about how this fixdt data type works on arduino (in the signal notation of simulink, an example of this variable is called sfix16_en5 - 16 is the word lenght, 5 the fraction lenght - and it's a fixed point data type which uses int16 as "container")
thank you
devobitch
