Topic: Help me Understand Memory Allocation (Analogous to PROGMEM) (Read 857 times) previous topic - next topic
tms8c8
Can I read/write data to flash in the Arduino DUE? Since the Due is a Von Neumann architecture, I find it hard to believe that this isn't supported in the IDE. I've seen some conflicting answers regarding this question, though. A couple of people said that it is not possible and a couple others have said that using "const" will automatically put the variable in the program memory.
I tried declaring a large array as a constant and the sketch size didn't increase. I would have expected that that the sketch size would increase.
e.g.
Code: [Select]
const byte Array[500] = {stuff}
should increase the "sketch size" by 500 bytes - but it doesn't. So does the compiler actually put these in ROM and the IDE just doesn't figure their size into the "sketch size" or ... ?
Thanks!
stimmer
Be sure to reference your array somewhere in your code - otherwise the linker will remove it.
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
tms8c8
Ah! Ok - that's probably why my simple "test" didn't change the sketch size. I just included it as a declaration and never used it.
Thanks!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
