Author Topic: Connecting tft screen to arduino uno r3  (Read 575 times)
Hi there today i received my new tft screen but it seems that u cant connect it in easy way so maybe someone could help me with it ?
2.4 inch TFT LCD Module Screen 240 x 320 Pixels ILI9325 Arduino Compatible
i got it from ebay
datasheet : http://www.newhavendisplay.com/app_notes/ILI9328.pdf
some pictures :
http://i36.tinypic.com/2rxijus.jpg
http://i38.tinypic.com/29gmtzp.jpg
http://i34.tinypic.com/23j3m2r.jpg
oh and i have sensor shield v5.0 to maybe its possible to connect that lcd to that shield !?
can someone please help me with this  its my first arduino and i have no idea what  to do smiley
« Last Edit: February 04, 2013, 11:38:10 am by artursm15 » Logged
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
A picture and link to your LCD screen would be helpful.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
It looks like the controller has an I2C and SPI interface mode, but that is not enabled on your LCD. However, there is an SPI interface to the SD card and Touchscreen as well as CS for the display being brought out. Would have been so much simpler if they had just made it a common SPI bus with individual CS lines for the display, SD, and touchscreen.
The SPI mode of the controller is set by setting the IB pins high or low. I would investigate modifying the circuit if I were you. I couldn't advise you directly what to do because the pictures do not show what I would need to see, but first find if the IB pins are brought out somewhere so that you can change them to SPI mode, then look to see if the SCLK, DI, and DO lines are brought out somewhere (probably share a DB pin) Then connect them all together for a single SPI bus, and use the CS lines to pick which devices you are communicating with. 6 lines total would give you access to an SD card, LCD, and touchscreen.
Otherwise, you are not going to have enough IO on the Uno to control that screen. Well, at least not without using latches.
Queens, New York
latches? You mean shift registers?
No. Latches, to expand an 8 bit data bus to a 16 bit data bus. You latch the upper byte.
Queens, New York
Your right, I was thinking of something else.
OP, there are TFT screens that are plug and play, and arduino compatible, why didn't you get one of those? The SD card slot is for a micro though, not the regular one like you have.
can u give me some of the models of thous tft screens ? its just im searching for some tft screen ho don't take all the pints ! or maybe there is some witch one i could just connect to my sensor shield v 5.0 !
Queens, New York
Do you have an UNO or Mega?
I looked for some TFT lcds but it depends on what pins you need.
This one can go on an UNO but it uses all the pins, however it can also be used on a Mega, and you would still have the other end pins.
http://www.ebay.com/itm/ATMEGA328P-ATmega16U2-2-6-TFT-LCD-Shield-w-Touch-Screen-for-Arduino-UNO-R3-A133-/251201079188?pt=LH_DefaultDomain_0&hash=item3a7cc04794
« Last Edit: February 04, 2013, 07:25:20 pm by HazardsMind » Logged
Solved thank you guys for help !
Narvik, Norway
I've got same kind of display..
Solution is ???  Which library and testcode ??
Ny
Melbourne, Australia
This may be of interest:
http://tronixstuff.wordpress.com/2013/04/26/tutorial-arduino-and-ili9325-colour-tft-lcd-modules/
Check out my Arduino tutorials at http://tronixstuff.com/tutorials - Order my new Arduino book from http://www.arduinoworkshop.com
