Topic: Can I power a Motor directly from Arduino Board? (Read 818 times) previous topic - next topic
janiemiec20
Hello,
I have Arduino Uno board, I wanted to make a simple robot that would move around. I was wondering if I can plug in two or more motor directly to the board?
I have read somewhere that it is not safe but the article did not give an alternative as to a different way of creating this circuit.
If I cannot connect motors directly, then how should I go about doing this? Transistors? (not sure how they work)
Thanks,
JimboZA
Here's  how to do that with a transistor....
Or this gives direction control
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
janiemiec20
Thank you,
I am really a newbie, do I need a specific kind of transistor? I have one that is labelled 2N 5060 M643.
What do those numbers mean?
JimboZA
I'm no expert on transistors I'm afraid, so can't really advise.
But according to this, that's a rectifier not a transistor.
MikMo
To give advice on transistors we need to know more about your motors, voltage / current draw.
If the motors are not too big, a common transistor to drive it could be the TIP120, you would also need a diode and a resistor for each motor.
