Leighton Buzzard, UK
Offline
Edison Member
« on: February 04, 2013, 02:51:15 pm » |
I'm working on a reflow oven for SMD circuit pretty much under control I'm wondering what sort of track separation I should be using for the mains side of the project (220 volts as I'm in the UK) any advice much appreciated  (or will this be my last post!?!)
Logged
there are only 10 types of people them that understands binary and them that doesn't
Global Moderator
Dallas
Online
Shannon Member
« Reply #1 on: February 04, 2013, 03:02:19 pm » |
A few weeks ago there was a fairly long discussion of the subject. Let me know if you can't find the thread.
Logged
Offline
Edison Member
« Reply #2 on: February 04, 2013, 03:15:52 pm » |
ah found it thanks I may well be ok (gulp)
Logged
uk
Offline
Sr. Member
« Reply #3 on: February 04, 2013, 03:44:57 pm » |
where is the thred be interested in having a look thanks
Logged
Offline
Edison Member
« Reply #4 on: February 04, 2013, 03:52:26 pm » |
Logged
Offline
Edison Member
« Reply #5 on: February 04, 2013, 05:20:29 pm » |
here's what I've been working on part of a larger project this is just the triac section (to turn an oven on and off)
tried it this evening with a neon as oven simulator 220 volts input switched on and off using the 'duino works a treat and all stays nice and cool
have to watch the triac as it's at mains potential so only finger test for heat when powered off
Logged
Offline
Edison Member
« Reply #6 on: February 04, 2013, 05:30:59 pm » |
and here's the board layout grid is .0125"
the opto-isolator has 4.7mm spacing to the ground plane to the rightleft (!) the power track is 7.2mm from the ground track above
« Last Edit: February 05, 2013, 11:12:06 am by mmcp42 »
Logged
United Kingdom
Offline
Faraday Member
« Reply #7 on: February 05, 2013, 04:29:34 am » |
What is the purpose of D3 in your circuit? You've drawn it as a diac, but diacs are normally used in phase shift dimmers and speed controllers, in conjunction with a variable resistor and a capacitor. The idea is that at a certain voltage, the diac breaks down and discharges the capacitor into the gate of the triac. I can't see that it serves any useful purpose in the circuit you have drawn.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline
Edison Member
« Reply #8 on: February 05, 2013, 07:39:08 am » |
er D3 is actually a diac one of the application circuits I saw suggested using one it does seem to work but I can easily remove it does the rest of the circuit (with the diode replaced with a wire) look ok? thanks for looking cheers Mike
Logged
Grand Blanc, MI, USA
Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #9 on: February 05, 2013, 08:02:49 am » |
I've used these optoisolators and just followed the examples in the datasheet, no diac required, as the output side includes a silicon bilateral switch which is similar to a diac.
Logged
United Kingdom
Offline
Faraday Member
« Reply #10 on: February 05, 2013, 08:04:58 am » |
The rest of the circuit looks OK to me. As the load is resistive, you could use a zero crossing opto triac such as MOC3042 instead of a random fire one, which would create less mains borne interference. But unless the heating element takes a lot of power, it's probably not necessary.
Logged
Port Angeles, Wa
Offline
Edison Member
Ultimate DIY: Arduino
« Reply #11 on: February 05, 2013, 08:38:05 am » |
Yes, D3 is clearly redundant, since thats an optical diac in the coupler. Is there any reason you opted to build your own versus use a Solid State Relay? You can get a ready to use 10 AMP SSR from MPJA http://www.mpja.com/, for example, for as little as $7.95.
Logged
United Kingdom
Offline
Faraday Member
« Reply #12 on: February 05, 2013, 08:50:52 am » |
SSRs cost a little more in the UK, however Farnell has a 1.2A one for £1.87 and a 2A one for £6.34, is that is enough for your heating element.
Logged
Offline
Edison Member
« Reply #13 on: February 05, 2013, 09:00:43 am » |
 thanks total power is only 1 kW (4.5 amps or so at 220 volts) seems I'm actually using a MOC3080X - which is zero crossing  Yes, D3 is clearly redundant, since thats an optical diac in the coupler. Is there any reason you opted to build your own versus use a Solid State Relay? You can get a ready to use 10 AMP SSR from MPJA http://www.mpja.com/, for example, for as little as $7.95. parts cost < £1, SSR > £10 easy choice really - I'm a cheapskate by trade  no major reason other than it's part of a larger project I'll have a look at what's available on this side of the puddle
Logged
