Topic: track separation for mains voltages (Read 949 times) previous topic - next topic
mmcp42
I'm working on a reflow oven for SMD
circuit pretty much under control
I'm wondering what sort of track separation I should be using for the mains side of the project
(220 volts as I'm in the UK)
any advice much appreciated :)
(or will this be my last post!?!)
there are only 10 types of people
them that understands binary
and them that doesn't
Coding Badly
A few weeks ago there was a fairly long discussion of the subject.  Let me know if you can't find the thread.
mmcp42
ah found it thanks
I may well be ok (gulp)
jonisonvespaa
where is the thred be interested in having a look thanks
mmcp42
here's what I found useful ...
http://arduino.cc/forum/index.php/topic,137049.0.html
mmcp42
here's what I've been working on
part of a larger project
this is just the triac section (to turn an oven on and off)
tried it this evening with a neon as oven simulator
220 volts input
switched on and off using the 'duino
works a treat
and all stays nice and cool
have to watch the triac as it's at mains potential
so only finger test for heat when powered off
mmcp42
#6
Feb 04, 2013, 11:30 pm Last Edit: Feb 05, 2013, 05:12 pm by mmcp42 Reason: 1
and here's the board layout
grid is .0125"
the opto-isolator has 4.7mm spacing to the ground plane to the rightleft (!)
the power track is 7.2mm from the ground track above
dc42
What is the purpose of D3 in your circuit? You've drawn it as a diac, but diacs are normally used in phase shift dimmers and speed controllers, in conjunction with a variable resistor and a capacitor. The idea is that at a certain voltage, the diac breaks down and discharges the capacitor into the gate of the triac. I can't see that it serves any useful purpose in the circuit you have drawn.
mmcp42
er
D3 is actually a diac
one of the application circuits I saw suggested using one
it does seem to work
but I can easily remove it
does the rest of the circuit (with the diode replaced with a wire) look ok?
thanks for looking
cheers
Mike
Jack Christensen
I've used these optoisolators and just followed the examples in the datasheet, no diac required, as the output side includes a silicon bilateral switch which is similar to a diac.
dc42
The rest of the circuit looks OK to me. As the load is resistive, you could use a zero crossing opto triac such as MOC3042 instead of a random fire one, which would create less mains borne interference. But unless the heating element takes a lot of power, it's probably not necessary.
pwillard
Yes, D3 is clearly redundant, since thats an optical diac in the coupler.
Is there any reason you opted to build your own versus use a Solid State Relay?
You can get a ready to use 10 AMP SSR from MPJA  http://www.mpja.com/, for example, for as little as $7.95.
dc42
SSRs cost a little more in the UK, however Farnell has a 1.2A one for £1.87 and a 2A one for £6.34, is that is enough for your heating element.
mmcp42
:) thanks
total power is only 1 kW (4.5 amps or so at 220 volts)
seems I'm actually using a MOC3080X - which is zero crossing :)
parts cost < £1, SSR > £10
easy choice really - I'm a cheapskate by trade :)
no major reason other than it's part of a larger project
I'll have a look at what's available on this side of the puddle
