Author Topic: Meddling with the runtime clock  (Read 172 times)
Space Coast Florida
Is there some way to set the run-time clock other than waiting 49 days for the clock to turn over. I need to certify that the rollover will be uneventful.
Seattle, WA USA
Online Online
Seattle, WA USA
Use micros(), instead. Works the same way, but a much shorter fuse.
Get Bitlash: http://bitlash.net
I use code like this in the Bitlash rollover example (https://github.com/billroy/bitlash/blob/master/examples/rollover/rollover.ino):
extern volatile unsigned long timer0_millis;
void setMillis(unsigned long newtime) {
uint8_t oldSREG = SREG;
cli();
timer0_millis = newtime;
SREG = oldSREG;
-br
Melbourne, Australia
Shannon Member
Lua rocks!
Just build your own time machine:
http://science.discovery.com/games-and-interactives/build-your-own-time-machine.htm
Space Coast Florida
This might take longer than 49 days.
Shannon Member
Lua rocks!
Good point.
Space Coast Florida
Use micros(), instead.Works the same way,
Instead of the run-time clock?
Please explain.
Fuse?
Seattle, WA USA
Online Online
Seattle, WA USA
No, instead of millis().
Fuse?
micros() ticks 1000 times faster than millis. Results in 0.01% of the time.
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
Substitute a variable in place of using millis() directly. Instead of
if ( millis() ... whatever ) { ...
use
unsigned long ms = millis();
if ( ms ... whatever ) { ...
Make sure the code works as desired that way, then to test what happens around rollover, something like this:
unsigned long ms = 4294957296;    //ten seconds before rollover
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
