Loading...
Pages: [1]   Go Down
Author Topic: Please explain why Pin13 and Serial.write misbehaving  (Read 259 times)
Offline Offline
Full Member
View Profile
I stripped my code to the minimum and I just don't understand why I am getting pin 13 toggling and Serial.write not working in one case but not in the other.
I have three files: Debug the arduino sketch, Debug.h (the library header file) and Debug.cpp (the C++ library file)
With Debug.cpp as is shown below, I get pin 13 toggling on an UNO board and nothing is printed to serial out.
If I replace the "array[halfarraySize];" with "float array[halfarraySize];" in Debug.cpp, pin13 and the serial print behave properly.  Can you please explain what I am doing wrong and/or what is going on?
Thanks in advance!
Debug sketch:
Code:
#include <Debug.h>
const int arraySize=118;
debugClass debug_object(arraySize);
  Serial.write("test");
Debug.h:
Code:
#ifndef Debug_h
#define Debug_h
#include "Arduino.h"
class debugClass{
public:
debugClass(const int arraySize);
    // Keep as many variables private as possible
private:
    int halfarraySize;
    float array[];
#endif
Debug.cpp:
Code:
#include "Debug.h"
debugClass::debugClass(const int arraySize){
const int halfarraySize = arraySize/2;
    // This needs to be declared or prints have issues
for(int i = 0; i < halfarraySize; i++){
array[i] = 0;
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
Just as a matter of interest, what is the code supposed to do apart from filling up half the array ?
Logged
Offline Offline
Full Member
View Profile
I'm trying to implement a circular buffer for some experiments
Logged
UK
Offline Offline
Tesla Member
View Profile
Would you expect to be able to define an array member field of unspecified size just by putting 'array[size];' in the body of the constructor? I would have thought you'd need to use a template to enable the size to be defined at instantiation time, or allocate the array dynamically. Perhaps what you're doing is legitimate, but it doesn't look that way to me; I suspect what you're actually doing is trampling over initialised memory that will be needed by the Arduino runtime later one.
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
I believe Peter is correct, look at this link, http://www.cplusplus.com/doc/tutorial/templates/ under Non-type parameters for templates
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Full Member
View Profile
I think you are referring to the Debug.h private declaration "float array[];" no?
You make a good point, and suspect your theory is correct.  However, shouldn't the variable be declared in the header file?  Perhaps my assumptions are incorrect (completely possible as I'm learning this as I go).
When you say the array size should be enabled at instantiation time, where would this be located?
Thanks for the help
Logged
Des Moines, WA - USA
Offline Offline
God Member
View Profile
Code:
template<int N>
class debugClass
private:
    const int   array_length;
    float       array[N];
public:
    debugClass() : array_length(N)
        for ( int i = array_length; i--; )
            array[i] = 0;
debugClass <12>    debug;
Logged
Offline Offline
Full Member
View Profile
Code:
template<int N>
class debugClass
private:
    float       array[N];
public:
            array[i] = 0;
First of all, thank you for kindly writing this.  Would this code be placed in Debug.h?
I'm reading up on Templates, I was not aware of them.
Logged
Offline Offline
God Member
View Profile
Except for that last line yes as the last line instantiates and instance with an array length of 12 named 'debug' - place that in an implementation file where used.  Adjust array length as necessary.
Logged
Offline Offline
Full Member
View Profile
Sorry but I can't wrap my head around this yet.  I'm still studying templates and dynamic memory to understand what is needed.I tried using templates but am getting errors
Debug sketch:
Code:
#include <Debug.h>
//debugClass debug_object(arraySize);
debugClass <arraySize> debug_object;
Debug.h:
Code:
#ifndef Debug_h
#define Debug_h
template<int N>
class debugClass
private:
    float       array[N];
public:
        for ( int i < array_length/2; i--; )
            array[i] = 0;
#endif
Debug.cpp:
Code:
#include "Debug.h"
debugClass::debugClass(){
Errors:
Code:
In file included from Debug.ino:1:
/Applications/Arduino.app/Contents/Resources/Java/libraries/Debug/Debug.h: In constructor 'debugClass<N>::debugClass()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Debug/Debug.h:16: error: expected initializer before '<' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/Debug/Debug.h:16: error: 'i' was not declared in this scope
Logged
Offline Offline
God Member
View Profile
Sorry I hadn't seen your question earlier -
Code:
template<int N>
class debugClass
    const int   halfarraySize;
    float       array[N / 2];
public:
    debugClass() : halfarraySize(N / 2)
        for ( int i = halfarraySize; i--; )
            array[i] = 0;
const int arraySize = 118;
debugClass<arraySize> debug_object;
« Last Edit: February 04, 2013, 08:18:33 pm by lloyddean » Logged
Pages: [1]   Go Up
Print
Jump to:
