Topic: im working on a home automated system and the webserver is acting weird (Read 3165 times) previous topic - next topic
michael040990
Feb 04, 2013, 09:17 pm Last Edit: Feb 04, 2013, 09:23 pm by michael040990 Reason: 1
ok heres my code
http://pastebin.com/u0ArQXCZ
when i connect to the 192.168.1.177 it shows something like this
http://i49.tinypic.com/2pzffbd.jpg
http://i45.tinypic.com/34qwqqf.jpg
http://i50.tinypic.com/14trd4p.jpg
and chainges every time you refresh or sometimes it wont even load
sometimes it will download a file called download with the contence of
http://pastebin.com/S6BBfEvi
the website is located here http://turnmylightson.no-ip.org/
im using arduino uno with the wizboy ethernet sheild connected through a tl-wr702n chinese router connected as a client to my home router
no serial communication seems to be going on through the arduino ide serial console
andsome times it says it can not find the serial port
this code worked a few times before do you think there is a problem with my arduino uno that doing this?
it seems my old code works fine what went wrong with the new code?
http://pastebin.com/73qqMwwt
SurferTim
If this is an Uno, you should leave D10-D13 alone. I see you might have something connected (or plan on it) to D10. A relay maybe?
And this is not right.
// it should be
Ethernet.begin(mac, ip, gateway, gateway, subnet);
The first gateway parameter is actually for the dns server ip, but the gateway works ok if you do not plan on using dns.
michael040990
#2
Feb 04, 2013, 10:00 pm Last Edit: Feb 04, 2013, 10:02 pm by michael040990 Reason: 1
thanks for pointing that out im trying it out now
it still crashed
and pin 11,12,13,4 will eventually go to the sd card reader
while pins 5,6,8,9 are relays and pin 3 is a ir led while pin 7 is a ir receiver
i got
Oops! Google Chrome could not connect to turnmylightson.no-ip.org
Suggestions:
Go to no-­ip.­org
Try reloading the page
Search on Google:
it looks like its not connecting to the webserver or not sending the header or something
if i ping 192.168.1.177 it comes back
Pinging 192.168.1.177 with 32 bytes of data:
Reply from 192.168.1.177: bytes=32 time=4ms TTL=128
Reply from 192.168.1.177: bytes=32 time=2ms TTL=128
Reply from 192.168.1.177: bytes=32 time=1ms TTL=128
Ping statistics for 192.168.1.177:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 1ms, Maximum = 4ms, Average = 2ms
so its connecting to the arduino so it has to be something with sending the client.write commands to the server
SurferTim
Now I think I understand.
Do you have your public ip registered with no-ip?
Do you have your public ip interface sending port 80 requests to 192.168.1.177?
Can you access the Arduino from the internet by ip address?
Does your ISP block port 80 requests to non-commercial ip addresses? Mine does.
michael040990
turnmylightson.no-ip.org>24.160.73.173>router>192.168.1.177>arduino
no-ip info>Host Type:DNS Host (A)
i can not access it through either turnmylightson.no-ip.org|24.160.73.173|192.168.1.177
i know the noip works because the other skitch i uploaded worked fine
and i tried to add
byte dns[] = {
  192, 168, 1, 1 }; // dns server
and
  Ethernet.begin(mac, ip, dns, gateway, subnet);
but i get the error
webserver_home_automation_with_status:35: error: 'byte dns []' redeclared as different kind of symbol
C:\Documents and Settings\Michael\My Documents\Arduino_instalation\arduino-1.0.1\libraries\Ethernet/Dhcp.h:64: error: previous declaration of '<anonymous enum> dns'
as stated before this is the origional one i had that worked fine
SurferTim
I was not sure if you meant it worked on the localnet or with no-ip. I use my own server code, and it has proven to be reliable. Maybe looking at it will help you.
http://playground.arduino.cc/Code/WebServerST
SurferTim
So upload mine into your Arduino and check it. I guarantee no viruses or spyware.   :D
edit: zoomkat is around somewhere. He has some good server code for stuff like this too.
michael040990
i did a little bit debugging and this is what is messing up the server
         //start debug
if(readString.indexOf("GET /=0")>=0){
           Relay1status = LOW;
           digitalWrite(Relay1, Relay1status);
           Serial.println("Lights are off");
         }//end if lightoff
         if(readString.indexOf("GET /?status=1")>=0){
           Relay1status = HIGH;
           Serial.println("Lights are on");
         }//end if lighton
           //read for fan
         if(readString.indexOf("GET /?status=2")>=0){
           Relay2status = LOW;
           digitalWrite(Relay2, Relay2status);
           Serial.println("Fans are off");
         }//end if fanoff
         if(readString.indexOf("GET /?status=3")>=0){
           Relay2status = HIGH;
           Serial.println("Fans are on");
         }//end fanon
           //read for relay3
         if(readString.indexOf("GET /?status=4")>=0){
           Relay3status = LOW;
           digitalWrite(Relay3, Relay3status);
           Serial.println("Relay3 iso ff");
         }//end if relay3off
         if(readString.indexOf("GET /?status=5")>=0){
           Relay3status = HIGH;
           Serial.println("Relay3 is on");
         }//end relay3on
           //read for relay4
         if(readString.indexOf("GET /?status=6")>=0){
           Relay4status = LOW;
           digitalWrite(Relay4, Relay4status);
           Serial.println("Relay4 is off");
         }//end if relay4off
         if(readString.indexOf("GET /?status=7")>=0){
           Relay4status = HIGH;
           Serial.println("Relay4 is on");
         }//end relay4on
           //read for relay5
         if(readString.indexOf("GET /?status=8")>=0){
           Relay5status = LOW;
           digitalWrite(Relay5, Relay5status);
           Serial.println("Relay5 is off");
         }//end if relay5off
         if(readString.indexOf("GET /?status=9")>=0){
           Relay5status = HIGH;
           Serial.println("Relay5 is on");
         }//end relay5on
//end debug
idk why or how but without it it loads up fine
SurferTim
You do not want to be doing this. Last time I looked at your code, relay5 is D10. That is the slave select for the w5100.
            //read for relay5
            Relay5status = LOW;
          }//end if relay5off
          }//end relay5on
SurferTim
From your code
int Relay5 = 10;
D4 has its own purpose if there is a uSD memory card in the slot. That is the slave select for it. If you never plan on using the uSD slot, you can use D4 for other stuff.
michael040990
once i have the main interface running and working the sd slot will be for customhtml and css websites but im not the far yet
michael040990
heres what i have so far thats working i still dont know how to log the relay states with out crashing it i remember somewere that serial.write is faster then serial.println so i replaced the client.println with client.wite
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
**relay1 - pin 6   //lights
**relay2 - pin 5   //fan
**relay3 - pin 8   //nc
**relay4 - pin 9   //nc
  **IRled - pin 3 //pwm
**IRrec - pin 7
#include <SPI.h>
#include <Ethernet.h>
int Relay1 = 6;
int Relay2 = 5;
int Relay3 = 8;
int Relay4 = 9;
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
  192, 168, 1, 177 }; // ip in lan
byte gateway[] = {
  192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){//start void setup
  pinMode(Relay1, OUTPUT); //pin selected to control relay1
  pinMode(Relay2, OUTPUT); //pin selected to control relay2
  pinMode(Relay3, OUTPUT); //pin selected to control relay3
  pinMode(Relay4, OUTPUT); //pin selected to control relay4
  //start Ethernet
  server.begin();
  Serial.println("http://turnmylightson.no-ip.org/ server test 1.0"); // so I can keep track of what is loaded
  Serial.begin(9200);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  }//end while not serial
}//end void setup
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          Serial.print(c); //for debuging
        }//end readString.length
        if (c == '\n') {    //if HTTP request has ended
          //send html data to client
          Serial.println(readString); //print to serial monitor for debuging
              client.println("HTTP/1.1 200 OK"); //send new page
           client.println();
           client.write("<HTML><HEAD>");
           client.write("<HEAD>");
           client.write("<meta name='apple-mobile-web-app-capable' content='yes' />");
           client.write("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
           client.write("<link rel='stylesheet' type='text/css' href='http://homeautocss.net84.net/a.css' />");
           client.write("<TITLE>Home Automation</TITLE>");
           client.write("</HEAD>");
           client.write("<BODY>");
           client.write("<H1>Welcome To My Home Automation Website</H1>");
           client.write("<hr />");
           client.write("<br />");
           client.write("<a href=\"/?status=1\"\">Turn On Bed Room Light</a>");
           client.write("<a href=\"/?status=0\"\">Turn Off Bed Room Light</a><br />");
           client.write("<a href=\"/?status=3\"\">Turn On Bed Room Fan</a>");
           client.write("<a href=\"/?status=2\"\">Turn Off Bed Room Fan</a><br />");
           client.write("<a href=\"/?status=5\"\">Turn On relay3</a>");
           client.write("<a href=\"/?status=4\"\">Turn Off relay3</a><br />");
           client.write("<a href=\"/?status=7\"\">Turn On relay4</a>");
           client.write("<a href=\"/?status=6\"\">Turn Off relay4</a><br />");
           client.write("</BODY>");
          ("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          //control arduino pin
          //read for Light
          if(readString.indexOf("GET /?status=0")>=0){
            digitalWrite(Relay1, LOW);
            Serial.println("Light is off");
          }//end if lightoff
            digitalWrite(Relay1, HIGH);
            Serial.println("Light is on");
          }//end if lighton
            //read for fan
            digitalWrite(Relay2, LOW);
            Serial.println("Fan is off");
          }//end if fanoff
            digitalWrite(Relay2, HIGH);
            Serial.println("Fan is on");
          }//end fanon
            //read for relay3
            digitalWrite(Relay3, LOW);
            Serial.println("Relay3 is off");
          }//end if relay3off
            digitalWrite(Relay3, HIGH);
          }//end relay3on
            //read for relay4
            digitalWrite(Relay4, LOW);
          }//end if relay4off
            digitalWrite(Relay4, HIGH);
          }//end relay4on
            //clearing string for next read
          readString="";
        }//end if HTTP request has ended
      }// end client.avalible
    }//end while client.connected
  }//end if client
}//end void loop
SurferTim
That code does not access Relay5 (D10) like the original code you posted, so it should work ok.
You are not using the uSD card now, but you will be. I highly recommend avoiding D4 until you are ready to use the uSD. But you can't use D10 now. It is already used. It should be manipulated by the ethernet library low level read and write functions after the setup() function.
