Topic: 350Mhz RF Remote. I know there is 315mhz and 433mhz. (Read 23911 times) previous topic - next topic
Mysticle31
I'm done for tonight.  Thanks for your help.
Instead of printing the code to the screen with serial.print.  Is there away to print the code to a pin?
I think I'd like to hook the button board up to the transmitter though the arduino and play from there.  I dont know.  Picking at straws I suppose.
Retroplayer
sure, in the interrupt routine, you could just do this instead of serial.print:
Code: [Select]
byte value;
value = digitalRead(2);
digitalWrite(3,value);
There may be an error with digitalWrite taking value instead of HIGH or LOW. If so, try:
Code: [Select]
int value;
instead of byte.
That should relay whatever it reads on pin 2 out to pin 3. There will be a delay of course, but as long as the delay is consistent, the transmitter *shouldn't* care.
If you get a chance to measure that voltage, let me know. We may have to do something in-between to get it all nice and happy.
As a last resort, you could try to figure out which pins on the PT2262 that the buttons are connected to and which pins the address are set for from the circuit. That will tell you what commands are what instead of trying to read the remote output.
You could always go with your original plan to hook the buttons up directly on the remote and control it that way, but I think getting this sorted out will be more useful to you in the long run. I won't be able to mess with it much this weekend, but if you haven't figured it out by Monday, I will grab one of my remote outlets and attempt it myself to see if there are any gotchas.
Mysticle31
Well I got home tonight and figured I'd look up all the values I've tried to use so far and come up with something.  It took a couple hours, but It's a nice course in simple programming!
Code: [Select]
int inpin = 2; // makes the input pin pin 2
int outpin = 3;  // makes the output pin pin 3
int val = 0;  // sets the initial variable to 0
// the setup routine runs once
 Serial.begin(9600);  // initialize serial communication at 9600 bits per second:
 pinMode(inpin, INPUT);  // makes inpin the input pin
 pinMode(outpin, OUTPUT);  // makes outpin the output pin
// the loop runs over and over forever
 int inpinState = digitalRead(inpin); //reads the state of the input pin
 digitalWrite(outpin, inpinState);  //writes the state of the input pin on the output pin
 Serial.println(inpinState); //displays the value of the input pin on the screen
 delay(0); // delay in between reads for testing
Results:
If I physically connect the transmitters signal line to the button boards signal line the remote works.  I can control the light.
If I run it though the arduino with the above code, I get nothing.  I can see the binary change happening as I push the button, but the lights don't respond.
What if there is a speed mismatch between what the arduino can process and what the button board and transmitter use?  So the binary doesnt get though right?  Like watching my arudino set at 9600 baud with a serial monitor set at 1200 baud?
Could it be an analog signal or a sign wave?  I dont know.  Scrapping for ideas.
Mysticle31
#33
Mar 09, 2013, 10:00 am Last Edit: Mar 09, 2013, 10:36 am by Mysticle31 Reason: 1
SUCCESS!!!!  It works!
I just had to get rid of the serialprint line.  I guess the extra little clock cycle that it took to print that line made the receiver not respond.
Now I just need to capture some codes.  I guess I have two ways to do this.
1) capture the codes using serialprint and copy paste into notepad and tinker until it works.  Hardcoded codes do sound nice.
2) put some code in the setup section that will say "press the light toggle switch" then capture that code into a variable called lighttoggle.  Then prompt the user "press the fan on button" then capture that code into a variable called fanon.
I know how to use serialprint and I know how to create variables now.  What I dont know is how to make it prompt, wait for input, then know when to move on to the next section.
Plus under option 2 I would have to store variables that were, 8, 16, however many bytes long and not just an instantaneous state change.
Retroplayer
#34
Mar 09, 2013, 04:31 pm Last Edit: Mar 09, 2013, 04:37 pm by Retroplayer Reason: 1
You just print the prompt out. Then you use this (in your loop):
Code: [Select]
if(Serial.available()){ //Someone entered something in the serial display
  byte c = Serial.read();
if(c > 0){ //We have a non-null value, so do something with it
  switch(c){
     case 'm': //'m' was sent
          //run some code meant for 'm'
         break; //always break after doing the command unless you want it to "fall through"
     case 'n': //'n' was sent...
         //do some code for 'n'
      //etc...
If you have multiple steps, like multiple prompts, keep a state machine (keep a count of steps) so it knows what step it is at.
In your case, it might make more sense to increment the steps based on the interrupt. That way your code knows when the button was actually pressed.
Code: [Select]
byte state = 0;
byte light_toggle;
byte fan_toggle;
#define maxStates 6 //if there will be six steps total
void loop(){
  switch(state){
    case 0:
Serial.print("Press the light toggle switch");
break:
    case 1:
light_toggle = value;
Serial.print("Light toggle command is: ");
        Serial.println(light_toggle, DEC);
        state++ //we have to increment the state here since no interrupt
    case 2:
        Serial.print("Press the fan toggle switch")
    case 4:
        fan_toggle = value;
Serial.print("Fan toggle command is: ");
        Serial.println(fan_toggle, DEC);
     //etc... for all states
void interrupt(){
state = state++ //increments the state counter
//....do normal interrupt code here
if(state > maxStates) state = 0; //reset the state counter
If your value is 8 bits use
Code: [Select]
byte value in your declaration, if it will be 16, use
Code: [Select]
unsinged int value
Retroplayer
There may be some minor errors in there. I always make stupid mistakes when writing code and only catch them when I go to compile. So, you may have to mess it, of course. It's just an example.
BTW, your address part of the command will (likely) always be the same for a particular device. So you really only need to capture that part once, then just store the command part for each button.
Retroplayer
I am very interested in home automation myself. I even have all the X0 goodies including all the software that lets you program intelligent control and control from the web, but I am currently only renting a house so I am limited in what I can do. I have always thought it would be nice to tie all the various pieces together at some point. Maybe I should start playing with it a little so I have all the chunks ready when I move on.
I tend to stay at the girlfriends over the weekend, so something like an 'away' macro that turned off all the lights, set the thermostat down, ocassionally turned on lights to make it appear that I was home, set the security system, etc.. would be nice. Also checking on the cats and being able to feed and water them remotely would be nice. Hmm... I may have to start playing again.
Mysticle31
Oh yeah.  I love this stuff.  I dreamed of working on one for awhile.  You need the arduino automatic cat feeder and sandbox scrapper with a little robot that will collect the doo doo and run it to the trash for you  :)  I swear possibilities are only limited by a persons imagination and technical ablilty.
I tried this:
Code: [Select]
byte state = 0;  //sets bytes vale to 0???
byte light_toggle; // creates byte light_toggle
byte value;  //creates byte value to display value
#define maxStates 6 //if there will be six steps total  (I'm not sure how this works.  There are 2 states on and off?)
   switch(state){ //like an if statement
    case 0:
    case 1:
light_toggle = value;  //what is this doing?  It's setting light_toggle = value.
        state++; //we have to increment the state here since no interrupt
And it prints "Press the light toggle switch" over and over again.
I'm not sure how #define maxStates 6 works.  Why do you need to know this?  Nothing ever references maxStates?
I think I need to somehow put the code together so that each state where we read a byte has it's own "if(c > 0)" section.  I'm not even close to understanding how that piece of code works yet.  It should just ignore all 0s so if it sees 0 then 0 then 0 then 0 then 0 it does nothing.  But if a 1 pops up it says "hey listen up write this down" for 8 bits and call that bit light_toggle and file it away.
Mysticle31
Just for fun I also tried playing with it with
  byte onbyte  = digitalRead(inpinState) | (digitalRead(inpinState)<<1) | (digitalRead(inpinState)<<2) | (digitalRead(inpinState)<<3) | (digitalRead(inpinState)<<4) | (digitalRead(inpinState)<<5) | (digitalRead(inpinState)<<6) | (digitalRead(inpinState)<<7);
added
Code: [Select]
  Serial.print(onbyte); //displays the value of the input pin on the screen
  //delay(0); // delay in between reads for testing
Retroplayer
It was repeating over and over again because the "state" is always going to be zero at least until an interrupt comes in. Hmm... sounds like we need another flag to tell whether it is the first time running so loop doesn't trigger every time. See, I told you I make stupid mistakes the first time around. lol
maxStates is the total number of states (no of prompts + number of entries.) So if there are three buttons to push, you have six states. Otherwise it would just keep counting forever. We want it to go back to the beginning when it has counts past the last state. I was doing that here:
Code: [Select]
Mysticle31
I tried your code again and recieve many Press the light toggle switch's still.
Code: [Select]
int logpin = 13;  // makes the logpin pin 13
byte state = 0;
byte light_toggle;
byte fan_toggle;
byte value;
  pinMode(logpin, INPUT); //makes logpin input for button
  digitalWrite(logpin, HIGH); // turn on pullup resistors
void loop(){
  switch(state){
    case 0:
    case 1:
void interrupt(){
state = state++; //increments the state counter
what is normal interrupt code?  is that what was in my void loop before?  I did have to add ;s on the end of all the state = state++ inorder to get it to compile.  Maybe that changed something?
I hooked up a pushbutton to pin 13, so that it would print binary code to the serial monitor only when I pressed the button.  So if I press both buttons at the same time, it prints binary to the screen.  Otherwise it goes to the transmitter.  I tried then putting that code into multiple digital writes, but it didn't work.
digitalWrite(outpin, HIGH);
  digitalWrite(outpin, LOW);
...etc.
Sadly, I'm coming to think that this project lies outside the realm of my abilities; even with the help of a more advanced, and kindhearted home automation enthusiast.  Time to take more programming classes.
Retroplayer
The missing ;'s were just another mistake. Again, I make a lot of them. I tend to program quickly and not worry about mistakes knowing (hoping) I will catch them later. Also, I am fairly new to C. I am more of a hardware guy.
The interrupt code is the function I named void interrupt(). You can name it whatever you want. You set what function to call on what type of interrupt with this statement in setup(): attachInterrupt(pin, function, mode.)
I apologize, my code was meant to be pseudo-code. The pieces were meant to be plugged into the example program not just run by themselves. I think that's why you were having trouble. I never set up the interrupts in my code. I will write something more complete for you to try. The 'normal interrupt code' part was suppose to be the stuff from the example.
Hang in there, I will post someting tonight for you.
Retroplayer
Unless I made a mistake, this should do what you want using the RCSwitch library:
Code: [Select]
#include <RCSwitch.h>
#define maxStates 3 //change this and the number of strings (char*) below to match the total number of codes you want to decipher.
byte state = 0; //variable to keep track of the states
char* prompts[]={"Press Light Toggle: ", "Press Fan Toggle: ", "Press next button name"}; //Serial strings for the various prompts
char* codes[]={"Light Toggle: ", "Fan Toggle: ", "Next button code: "}; //Serial strings for the names of the codes
RCSwitch mySwitch = RCSwitch(); //Make an instance of the RCSwitch library
  mySwitch.enableReceive(0);  // Receiver on interrupt 0 => that is pin #2
  Serial.println(prompts[state]); //This will print the first prompt in the array of prompts to get things started
    if (mySwitch.available()) { //This code only runs when a button was decoded
    int value = mySwitch.getReceivedValue();
    if (value == 0) { //Something was seen, but the code couldn't decode it
      Serial.print("Unknown encoding");
    else { //Or a valid code was found
      Serial.print(codes[state]); //Displays the name of the code based on the state
      Serial.print( mySwitch.getReceivedValue() );
      Serial.print(" / ");
      Serial.print( mySwitch.getReceivedBitlength() );
      Serial.print("bit ");
      Serial.print("Protocol: ");
      Serial.println( mySwitch.getReceivedProtocol() );
      Serial.println(" ");
      state++; //increment to the next state
      if(state > maxStates) state = 0; //reset the state counter if we reach the maximum step
      Serial.println(prompts[state]); //prints the next prompt. Starts back at the beginning if max was exceeded.
    mySwitch.resetAvailable(); //reset the "available" flag after getting a code
Mysticle31
You know.  I think the problem lies in how RCSwitch is used with my remote.
Unmodified RCSWitch, VirtualWire and even some IRLibraryies do nothing with the input from the button board.  But I get something with digitalRead or Serial.read.  I cant even manually copy and paste some stuff into hardcoded tx examples.
I started a new thread in programming to see if I could pick some brains.  It's gone more than project guidance ha ha :)
Retroplayer
Your remote is using an SC2262 or PT2262, right?
I set up a quick configuration myself last night and tried it and had no success either. But when I looked inside the module it said 319Mhz on the TX module and I only have 315 and 434 modules. There is also AM and FM modulated modules (not sure which scheme the remote is using.) So I may not have the right modules for my remotes. I have a receiver outlet in my junk box somewhere. I will have to dig for it and try it again with that.
I ordered several PT2262 and PT2272 ICs a couple of years back and experimented with them over breadboards (without a micro) using my RF modules and that worked, so perhaps I can also set up my own "remote" on a breadboard to make sure the library is doing what it is suppose to be doing.
What's interesting is that I noticed the LED flickering like crazy on the Arduino while running the library and it would flicker faster when I pressed a button on the remote, so it is seeing something. It also mellowed out when I pulled it up with a 1K resistor and only flickered when I pressed a remote button. I don't see anything in the datasheet telling me I need to do that, though.
The good news is that it looked like the code I posted would work if it picked up the data.
