Topic: [SOLVED] Number/Hash sign in URL after submitting form (Read 975 times) previous topic - next topic
mtruijen
Feb 04, 2013, 10:33 pm Last Edit: Feb 05, 2013, 09:32 pm by mtruijen Reason: 1
Hello Arduino gurus.
I have developed a small program that will read the request header and returns a response header and message to client.
Everything works great except one small annoying thing.
When I submit the form, it appends a number/hash symbol to the URL. I have set the form action to post to itself (method is POST).
Please check it out here: http://arduino.martin.us.com
Any help would be highly appreciated.
SurferTim
Seemed ok from here. Maybe you should post your code.
mtruijen
In order to reproduce, you would have to submit the page a couple times...
Coding Badly
First, I suggest you fix the HTML problems...
http://validator.w3.org/check?uri=http%3A%2F%2Farduino.martin.us.com%2F&charset=%28detect+automatically%29&doctype=Inline&group=0
Maybe that will resolve the hash problem.
mtruijen
Great suggestion to run it through a validator. Some embarrassing mistakes. Got them fixed. Still the same issue ...
mtruijen
#5
Feb 05, 2013, 08:54 am Last Edit: Feb 05, 2013, 09:36 am by Coding Badly Reason: 1
Here's my code:
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,20);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
const char* iContentLengthPtr;
const char* kContentLengthPrefix = "Content-Length: ";
typedef enum {
 eIdle,
 eStatusCodeRead,
 eReadingContentLength,
 eReadBody,
 eSkipToStartOfBody,
 eReadingBody,
 eReadFormElement
} tHttpState;
int laserPin = 9;
 // start the Ethernet connection and the server:
 Ethernet.begin(mac, ip);
 server.begin();
 // initialize the digital pin as an output.
 pinMode(laserPin, OUTPUT);
 tHttpState iState = eStatusCodeRead;
 int iContentLength = 0;
 int iElementCount;
 iContentLengthPtr = kContentLengthPrefix;
 char e[2][16];
 char *element;
 // listen for incoming clients
 if (client) {
   // client.available() returns the number of bytes the client has yet to return
   // This number decreases everytime we do a client.read()
   while (client.available() > 0) {
       char c = client.read();
       Serial.write(c);
       switch(iState) {
         case eStatusCodeRead:
           if (*iContentLengthPtr == c) {
             iContentLengthPtr++;
             if (*iContentLengthPtr == '\0') {
               iState = eReadingContentLength;
         case eReadingContentLength:
           if (isdigit(c)) {
             iContentLength = iContentLength*10 + (c - '0');
             iState = eSkipToStartOfBody;
         case eSkipToStartOfBody:
           if (client.available() <= iContentLength) {
             iState = eReadingBody;
             iElementCount = 0;
         case eReadingBody:
             if (c == '=') {
               iElementCount++;
               memset(e[iElementCount], 0, 16);
               element = e[iElementCount];
               iState = eReadFormElement;
         case eReadFormElement:
           if (c != '&') {
             *element++ = c;
         default:
   if (strcmp(e[1],"on") == 0) {
     digitalWrite(laserPin, HIGH);
     digitalWrite(laserPin, LOW);
   client.println("Content-Type: text/html charset=utf-8");
   client.println("Connnection: close");
   client.println();
   client.println("<!DOCTYPE html>");
   client.println("<html>");
   client.println("<head>");
   client.println("<meta charset=\"UTF-8\">");
   client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
   client.println("<link rel=\"stylesheet\" href=\"http://code.jquery.com/mobile/1.2.0/jquery.mobile-1.2.0.min.css\" />");
   client.println("<script src=\"http://code.jquery.com/jquery-1.8.2.min.js\"></script>");
   client.println("<script src=\"http://code.jquery.com/mobile/1.2.0/jquery.mobile-1.2.0.min.js\"></script>");
   client.println("<title>Martien's Arduino</title>");
   client.println("</head>");
   client.println("<body>");
   client.println("<div data-role=\"page\">");
   client.println("<div data-role=\"header\">");
   client.println("<h1>Martien</h1>");
   client.println("</div>");
   client.println("<div data-role=\"content\">");
   client.println("<form method=post action=\"http://arduino.martin.us.com/\">");
   client.println("<fieldset data-role=\"fieldcontain\">");
   client.println("<label for=\"flip-1\">Laser</label>");
   client.println("<select name=\"flip-1\" id=\"flip-1\" data-role=\"slider\" data-mini=\"true\">");
   client.write("<option value=\"off\"");
     if(!bitRead(PORTB, 1)) client.write(" selected");
     client.println(">Off</option>");
   client.write("<option value=\"on\"");
     if(bitRead(PORTB, 1)) client.write(" selected");
     client.println(">On</option>");
   client.println("</select>");
   client.println("</fieldset>");
   client.println("<input type=submit value=Submit />");
   client.println("</form>");
   client.println("</body>");
   client.println("</html>");
   client.stop();
Moderator edit: [code] [/code] tags added.
Coding Badly
jQuery appears to be the culprit.
mtruijen
Oh really? Thanks so much for finding that out. I will see if I can figure out what in JQuery is causing this.
mtruijen
Added data-ajax="false" to the form element and issue was resolved  :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
