Loading...
Pages: [1]   Go Down
Author Topic: using flex sensors to control servos  (Read 254 times)
Offline Offline
Newbie
View Profile
Hey guys im working on a little project where im trying to see if i can cook myself dinner using a robotic arm. ive got flex sensors sewed into a full arm glove and im using an xbee connection to the arm. the arm is just a little rough something i put together using mechano. Im not a programmer, this is just something i do for a hobby
so, the flex sensors control the servo movement over an xbee radio connection
m having problems with the code though and its driving me nuts. there was some good info on a topic like this before but i couldnt get the code to work for me. here it is
the sender
Code:
// Set up the sensor pin numbers
int Flexsensor[3] = {1, 2, 3};
// Save the values sent, so a new value is sent only when a change occurs
int sentValues[3];
// Change these if your minimum value is greater than 0
int from[] = {0,0 ,0};
// Change these if you maximum value is less than 1023
int to[] = {1023,1023,1023};
   for(int i=0; i<3; i++)
     int val;
       // Read a sensor's value
       val = analogRead(Flexsensor[i]);
       // Map it to the servo range using it's min/max range
       val = map(val, from[i], to[i], 0, 179);
       // If the new val is not the same as the last val sent
       if(val != sentValues[i])
        Serial.print("<"); // Start of packet marker
        Serial.print(i);     // which servo to move
        Serial.print(":");  // delimiter
        Serial.print(val);  // servo position to move to
        Serial.print(">"); // End of packet marker
          // Record the value sent, so we don't send again unless there is a change
        sentValues[i] = val;
and the receiver
Code:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
boolean started = false;
boolean ended = false;
char inData[24];  // Make sure this is big enough for your data
byte index = 0;
  myservo1.attach(8);
  myservo2.attach(9);
  myservo3.attach(10);
   while(Serial.available() > 0)
      char aChar = Serial.read(); // Read a single character
      if(aChar == '<') // Start of packet marker
         started = true;
         ended = false;
         index = 0; // Initialize array index
         inData[index] = '\0'; // Keep string NULL terminated
      else if(aChar == '>')
         ended = true;
         inData[index] = aChar; // Store the character
         index++; // Increment the position to store the next character
   if(started && ended)
      char *token = strtok(inData,":"); // Extract servo number as string
      if(token)
         // We got a servo number as a string. Make it a number
         int servoNumber = atoi(token);
         // Now, get the position
         token = strtok(NULL,""); // NULL to keep parsing same string.
         // no delimiters because we want all of the rest of the string
         if(token)
            // We got a position
            int position = atoi(token);
            // Now, move the right servo
            switch(servoNumber)
               case 0: myservo1.write(position); break;
               case 1: myservo2.write(position); break;
               case 2: myservo3.write(position); break;
can anyone see why this wont work for me?
also i found other example code that the owner claims to work for him
sender
Code:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
byte index = 0;
  myservo1.attach(8);
  myservo2.attach(9);
         started = true;
         ended = false;
         ended = true;
      if(token)
         if(token)
            switch(servoNumber)
and the reciving
Code:
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
myservo1.attach(2); // attaches the servo on pin 9 to the servo object
myservo2.attach(3);
myservo3.attach(4);
myservo4.attach(5);
myservo5.attach(6);
if(Serial.available() >=5)
byte servoAng1 = Serial.read();
byte servoAng2 = Serial.read();
byte servoAng3 = Serial.read();
byte servoAng4 = Serial.read();
byte servoAng5 = Serial.read();
// Send the servo to the position read...  (note: you get to make this happen)
myservo1.write(servoAng1);
myservo2.write(servoAng2);
myservo3.write(servoAng3);
myservo4.write(servoAng4);
myservo5.write(servoAng5);
any help you can give me would be greatly appreciated. this block is driving me nuts
Logged
Offline Offline
Newbie
View Profile
the sender
Code:
int sentValues[3];
     int val;
and the receiver
Code:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
byte index = 0;
  myservo1.attach(8);
  myservo2.attach(9);
         started = true;
         ended = false;
         ended = true;
      if(token)
         if(token)
            switch(servoNumber)
sender
Code:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
byte index = 0;
  myservo1.attach(8);
  myservo2.attach(9);
         started = true;
         ended = false;
         ended = true;
      if(token)
         if(token)
            switch(servoNumber)
and the reciving
Code:
#include <Servo.h>
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
myservo2.attach(3);
myservo3.attach(4);
myservo4.attach(5);
myservo5.attach(6);
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Have you gotten it to work first using wired connections like below? Flex sensors may not be a good choise for a position sensors.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
no. i dont know how id get the arduino to distinguish between different flex sensors.
what i mean is i dont know how to get the ardino to use data from flexServo1 to turn myservo1, and keep that seperate from the other sensors and servos.
im able to do this with code written for 1 sensor controlling 1 servo but i dont know how to add more without it going crazy. do you know how i would add more sensors and servos?
that video looks pretty impressive, is he using accelerometers? id like to try that next and i have a few wii controllers at home that would do the trick, but id like to get to use the flex sensors first. i saw a kid using one for his science fair and i thought it looked like a nice project
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
why not send the data as a string, and split it on the receiving end.
Send:  <150,180,45>
receive after split:
servo1 = 150
servo2 = 180
servo3 = 45
If you use the string method, then your receiving code is nearly there. You just need to add another IF statement to look for a comma ',' and change the array the data goes into.
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Newbie
View Profile
i get what you mean. im just not sure how to write that in code. ill look into string writing though. thanks for your help
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
No no, dont use strings, send it as an array, but set it up like a string. '<','1','5','0', ',(separating comma)' ,'1','8','0', ...'>'
Logged
Offline Offline
Newbie
View Profile
something like this?
sending
Code:
int flexSensor[3] = {1,2,3};
int sentValues[3];
int from[] = {420,420 ,420};
int to[] = {480,480,480};
     int val;
       val = analogRead(flexSensor[i]);
receiving
Code:
#include <Servo.h>
String readString, servo1, servo2, servo3;
Servo myservo1, myservo2, myservo3;  // create servo object to control a servo
   if(Serial.available() > 0)
    char c = Serial.read();  //gets one byte from serial buffer
    readString +=c;
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        servo1 = readString.substring(0, 4);
        servo2 = readString.substring(4, 8);
        Serial.println(servo1);
        Serial.println(servo2);
        Serial.println(servo3);
          //convert readString into a number
        int n1 = servo1.toInt();
        int n2 = servo2.toInt();
        int n3 = servo3.toInt();
        // auto select appropriate value, copied from someone elses code
        myservo1.write(n1);
        myservo2.write(n2);
        myservo3.write(n3);
         readString=""; //clears variable for new input
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
Close, but it better to check if the incoming char is NOT equal to ',' and store the variables, and if it is equal, to switch the array.
Logged
Pages: [1]   Go Up
Print
Jump to:
